93 gs300 wheel stud issue
Old 09-18-12, 12:06 AM
ksunfresh
ksunfresh's Avatar
Default 93 gs300 wheel stud issue
So I have a 1993 gs300 and i got 24mm spacers on the back im trying to remove for 10mm ones. Reason is because i got wider wheels so i can pull off the wheels but not the spacer. 2 studs are NOT stripped they seem like they are not seated. So when I go to loosen the lugnut on the spacer the stud spins freely with the lugnut. I have this problem on Rear Studs only. What im asking is how do i go about fixing this issue? By the way the studs were replaced before with 1998 toyota tacoma studs because they are a bit longer then oem gs300 ones. they were seated and welded on for security. i have a total of 3 studs i need to either replace with Tacoma ones or possibly just reweld? Buckys will not replace my studs for Tacoma studs only OEM ones. I cannot go back to oem ones because the hub was drilled to fit this Tacoma ones in the first place.. PLEASE any input advice anything will help.. BTW I was able to remove the lug nuts on the 2 of the 3 studs that are not seated properly I cannot get one out.
Old 09-18-12, 05:51 PM
GldnBbyNut
GldnBbyNut's Avatar
had the same issue on my S13....youre most likely gonna have to reweld it? is the nut still torqued all the way down?
Old 09-18-12, 08:23 PM
ksunfresh
ksunfresh's Avatar
Got the lug nut off today i think the splines are stripped so i can pull the spacer off i put alot of JB weld on the back and front hopein that will fix this issue. any opinions? if not should i just buy toyota tacoma studs put them in and then tac weld it maybe?
Old 09-18-12, 08:25 PM
ksunfresh
ksunfresh's Avatar
Old 09-19-12, 07:33 AM
GldnBbyNut
GldnBbyNut's Avatar
id go with the second option! do it right the first time and youll be a whole lot better off!
soleeasii
08-11-15 01:54 PM
bcorey
05-26-11 10:48 PM
Navigatn
Wheels, Tires & Brakes Forum
01-18-11 01:49 PM
pizdets17
10-26-09 09:21 PM
Ken'sGS300
09-18-05 08:28 PM
Quick Reply: 93 gs300 wheel stud issue
