w58 swap?
Old 05-04-11, 07:26 AM
jrARISTO
jrARISTO's Avatar
Default w58 swap?
I read a bet about the swaps on her but most of everyone gos with the r154 tranny. But I'm going with the w58 tranny. They say it builts right up and i don't need to extend the shifter, but what about the drive shaft and the sensors. This is were I'm at I have moved my ebrake already I have the clutch assembly not mounted but I have everything I need. I'm about to get a w58 with bell housing and driveshaft from an sc300...and I'm using my auto ecu. If someone can clarifie just a little it would great!
Old 05-07-11, 10:28 AM
jrARISTO
jrARISTO's Avatar
I have all this people read my thread but no one has in answer that's crazy. Will I almost done mounting my clutch paddle and clutch master then that's done. All i need now is the Flywheel and clutch. Then its time to put the tranny in. Yeah..
Old 05-09-11, 09:45 AM
GS300_1996
GS300_1996's Avatar
I am intrested in this swap to, only to move on from my auto. not looking to go turbo or anything at this time. does this tranny bolt right up with 2jzge? is there any issue to look for with obd2? what year is your car?
Old 05-09-11, 11:37 AM
jrARISTO
jrARISTO's Avatar
Yeah I'm not going turbo right now, I don't know if it builts up or not you not need to get the bell housing from a newer supra...I'm not shear what driveshaft you would uave to use.....I have a 93 gs....but ill put everything I did or ill pm you with what iv been doing
Old 05-10-11, 07:19 AM
GS300_1996
GS300_1996's Avatar
that will be great help...thanks...btw mine is a 96 and has the 5 speed auto with only 3 shifts working i think. so as soon as it dies i am going for this manual swap. hopefully it will last longer and not cost as much....
Old 05-10-11, 01:34 PM
jrARISTO
jrARISTO's Avatar
If you are going to get do the swap start getting everything you need and save money for the unexpected
Old 05-24-11, 09:38 AM
jrARISTO
jrARISTO's Avatar
Update on my swap, my clutch master is in and so is my peddle assembly. Have my flywheel just have to go get it resurfaced. I orderd my clutch kit, getn comp racing stage 2. And my my slave cylinder...getting that today and my clutch kit tomorrow.. then on to swapping trannys...ha ha ha almost done. I dont know how to post pics on here so sorry. But will post what go's on and what prob I come across.
Old 05-30-11, 04:32 PM
jrARISTO
jrARISTO's Avatar
I got everthing in so now I need to get some days off to put in the tranny.
Old 06-23-11, 10:26 AM
jrARISTO
jrARISTO's Avatar
Update on my swap put everything in. so my car is manual now yeah! I wish I can post up pics but i don't know how or even a vid. The swap wasent to bad. The hard part is putting in the tranny everything realy did bolt up just right. The drive shaft is to short from the auto and manual shaft so you do have to extend it or make a custom one. You can us the auto diff from the gs. You can us the auto ecu as will I havent had any problems. You really dont have to extend the shifted houseing my shifted housing was about 2in or 3in to close to the radio so i just extended my shifter about 4in or so.
Old 06-24-11, 07:40 AM
bsepko
bsepko's Avatar
Glad to hear this worked out.
Old 06-26-11, 01:40 AM
VSRgs300
VSRgs300's Avatar
so what did you end up doing for the driveshaft?
Old 06-26-11, 06:26 PM
jrARISTO
jrARISTO's Avatar
For now I welded the front drive shaft of the sc to the auto gs300. I don't have big power so it wotks for me for now..but latter down the road I'm going to get a custom drive shaft.
Old 06-26-11, 06:37 PM
m1k3yg
m1k3yg's Avatar
Hey man im actually doing this in a bout a month, so I was wondering if you could share the measurement for the driveshaft, n I need a lil help wit the stuff for the clutch pedal assembly, pictures are a little more helpful for me, email pics would be awesome
Old 06-26-11, 06:46 PM
m1k3yg
m1k3yg's Avatar
Btw does the original ecu work? Mine's a 93 n the auto tranny kicks super hard when I shift to drive, takes forever to shift from second to 3rd
Old 06-26-11, 06:51 PM
jrARISTO
jrARISTO's Avatar
Yeah I can sharesome info give me your email
Quick Reply: w58 swap?
