Length of R154 shifter extension for First Generation GS300?
Old 01-13-11, 03:00 AM
garethr
garethr's Avatar
Default Length of R154 shifter extension for First Generation GS300?
Does anyone know how much the Mk3 Supra (MA70) R154 shifter must be extended for a 1st gen GS300 (JZS147)?
I've spent some time searching CL, but I haven't been able to find this information.
Old 01-13-11, 03:42 PM
stockhatch
stockhatch's Avatar
It would be best to just measure so you can put it exactly where you want it.
Old 01-13-11, 04:19 PM
garethr
garethr's Avatar
True, especially since there's a manual '95 Soarer sitting next to the '95 Aristo on my drive, so I can at least measure the Aristo against that , but I thought I'd ask in case someone already had the info. R154s are more and more difficult to find over here, but if you do find one it will be out of an MA70, Soarer 'boxes make hens' teeth look common.
Old 01-14-11, 05:14 AM
jminsd
jminsd's Avatar
I just finished extending mine last week. I extended mine 6" and it just makes it into the exhisting cutout for the auto shifter. My shifter itself has a swan neck in it and it leans a bit to far back for me. I am going to straighten out the bends or or get the staight one and it will be perfect. I have seen other extensions from 5" to 8" here on the forums.
Old 01-17-11, 03:49 AM
garethr
garethr's Avatar
Thanks for the info.
Old 02-18-13, 07:05 AM
highdunk
highdunk's Avatar
So what's is the best length ? To extended it
Old 02-18-13, 10:51 AM
joewitafro
joewitafro's Avatar
Check out my swap thread highdunk.. I think a 6" extension would fit the shifter in place of the stock auto hole, but unless you have a straight up and down shifter it might be a tad uncomfortable. Mine was left with a stock soarer shifter housing on it which lengthens it like 3" total with the swan of the shifter and I made it possible to do this. Here's the final placement.
Old 02-26-13, 09:13 AM
jaymil31
jaymil31's Avatar
Default re: the best length
The max is 6 inch extension which totally equals 8 inches total in the original auto whole. The one thing you have to be aware of the geometric position of the shifter or you will not be able to get the transmission in 5 at high speeds.
BAD954BOI
Performance & Maintenance
45
04-15-15 05:41 AM
BuffNStuff
10-07-14 12:35 PM
95SC3T
04-14-14 09:01 AM
blacksc
SC- 1st Gen (1992-2000)
02-13-14 03:29 PM
TRDmike
SC400 / 300 Classifieds
19
01-28-12 08:36 AM
Quick Reply: Length of R154 shifter extension for First Generation GS300?
