Official DIY / How To
Old 10-01-14, 11:47 PM
  #106
Z3RK
Z3RK's Avatar
Default 94 GS300 spark plug and valve cover gasket replacement
Hey has anyone changed the valve cover gasket and spark plugs on a 1st gen GS? I think I have an idea of what to do but I don't want to start removing things blindly and mess something up. So can anyone give a quick ran down on what to do or what to look out for? Thanks much appreciated!
Old 10-02-14, 10:32 PM
  #107
joewitafro
joewitafro's Avatar
The hardest part is plugging the coolant line under the throttle body and removing the throttle body. Should be rather straight forward after that. Do you have the manual?
Old 10-05-14, 06:37 PM
  #108
Z3RK
Z3RK's Avatar
No I don't I've been looking for one but so far the ones I've seen are really expensive. And yea thats kinda what I thought also but just want to make sure so I don't mess anything up. Thnx for the info.
Old 10-06-14, 10:46 AM
  #109
joewitafro
joewitafro's Avatar
I can hook you up with an electronic PDF version of the manual if you want, just PM me and I can help you download it.
But yeah, pretty much you want to prevent getting coolant down in spark plug galley so after you remove the little center covers on the front and back you can stuff the center with some rags or paper towels, and after removing your intake and the nuts for the throttle body, you will be able to "slide" it on its three or four big studs, but you can't remove it unless that bottom coolant line is pulled off and plugged. Once that is done and your throttle body is out of the way, you should have some pretty good access to removing the valve covers and replacing the gaskets, along with the spark plugs and wires if need be.
Old 10-09-14, 07:54 PM
  #110
Z3RK
Z3RK's Avatar
Yes that would be perfect I've been going nuts without one for both my cars. Thanks I really appreciate it and the advice as well. I feel a bit more confident now to get started on it.
Old 10-19-14, 05:54 PM
  #111
rohanstar
rohanstar's Avatar
i wanna know how to remove OME side skirts please help
Old 08-26-15, 01:55 PM
  #112
kene
kene's Avatar
Default Swapping Aristo TT trans into a GS300
https://www.clublexus.com/forums/gs-...ml#post9162845
Old 10-06-16, 01:47 AM
  #113
Nfinitvic
Nfinitvic's Avatar
Can someone please give me a link to a DIY for the steering rack!!!
Old 12-28-16, 05:34 PM
  #114
kene
kene's Avatar
This may help:
https://www.clublexus.com/forums/sus...ement-diy.html
Old 06-22-17, 01:47 PM
  #115
phemobay
phemobay's Avatar
Default Ignition timing missed
Hello Lexus people,
my GS300 Ignition was changed and the car stated but missed timing
the engineer didnt get the timing right so i hear a sound (kra) whenever i do a sharp rev but when i do a normal rev (slowly) it doesn't make the noice.
note that I dont have anyone with timing light but i have volt metre.
please what are the side effect and the solution
can it knock my engine if drive to a distance place as it is now
Old 03-20-21, 10:32 PM
  #116
DDuong95
DDuong95's Avatar
Default Hey man could I get that pdf on valve cover gasket?
[QUOTE=joewitafro;8739378]I can hook you up with an electronic PDF version of the manual if you want, just PM me and I can help you download it.
I'm doing my spark plugs and valve cover gasket tmrw if you could share that pdf with me that would be sick.
devonduong95@gmail.com
tsx2isF
IS F (2008-2014)
07-26-16 11:09 AM
UNOHOO
IS - 1st Gen (2001-2005)
10-19-11 04:52 PM
g2racer
Performance & Maintenance
06-08-11 09:39 AM
phamduy
03-23-07 02:32 PM
Dx3
SC- 1st Gen (1992-2000)
07-23-04 05:11 AM
Quick Reply: Official DIY / How To
