GS300 vs. SC300
Old 07-09-07, 01:41 AM
tuninghaus
tuninghaus's Avatar
Default GS300 vs. SC300
hey guys, i've had sc300's and was curious, do the SC300's and the GS300 use the same diff? same diff mounts and location?
would a SC300/supra diff bolt on to the 1st GEN GS300?
i'm almost pretty sure the driveshaft is a different length right between the two right??? the transmission would probably be the same?
only difference is the driveshaft? i guess tranny tunnel would be a bit different too. wondering if anyone has done a TH400 swap in the 1st gen GS?
engine bay clearance on the exhaust side seems to be a lot more restricted on the GS300 vs. the SC300.
curious if anyone has went NA-T with the GS300 and which manifold (exhaust) they used?
Old 07-09-07, 09:37 AM
nyARISTO
Sunroof Surfer
nyARISTO's Avatar
well if u have a mani. SC300 then yes rear is diffrent VS. the auto diff its higher gears which means more top end (lil bit tho)... but mounts and everything is the same and as far as driveshaft very diff in lengths..
Old 07-09-07, 10:29 AM
MDSC
MDSC's Avatar
i'm pretty sure the white 9sec GS has a Th400, check on youtube
Old 07-10-07, 03:59 PM
twojayzee
twojayzee's Avatar
GS300PNP has a TH4 in his 1GN GS3
Nauta
Performance & Maintenance
12-12-14 06:01 PM
criminalR1
03-27-09 07:26 PM
B.Diddy
01-07-05 09:11 AM
Quick Reply: GS300 vs. SC300
