Sd navi programming
I believe all you have to do is flip up the small door above the hazard button, press in on the old SD card to release it, pull it out, insert new SD card until it locks into place, and close the small door.
i know how to put it in.. And where it goes.. My question is does it need programming by the dealer. Card is not being read by navi
The install notes says for the Power to be OFF, and as you pull out the SD Card check the orientation of the card and be sure to reinstall the new card the same way.
If it isn't working check to see if the card can be inserted a different way.
FYI- I checked mine and the Label is Up and the contacts are down and go in first.
Good Luck
Good Luck
Good Luck
Good Luck
