2015 FSport AWD - Brake Flush Help
Since I have few days off now I thought of doing a brake fluid flush. Should only take couple of hours or less I guess.
- Can someone tell me what's the order of drain and fill? Most common I have seen is Rear Right, Rear Left, Front Right, Front left. What about the Order in GS?
- If you have done this please share what technic you used. One person with a Vacuum pump or with a helper to pump the brake pedal?
Usually start with the caliper furthest away from the brake master cylinder. If someone is pumping the brakes for you, you should check the brake fluid for bubbles as they pump. when the the bubbles disappear, the brake pumper holds down the brake pedal all the way down and then you can tighten the bleeder valve and proceed to the next caliper. PS, make sure you have a lot of brake fluid in the reservoir.
I want to hear as well from someone who's done it.
I've heard there is something special about the rear where instead of having someone pump the pedal several times, you simply put pressure on and let the ABS pump do the work. Otherwise, it's just like any brake flush.
Why are you doing a brake flush on a 2015?
Thank you all. Took me close to 2 hours from Start to Finish.
Before I started, my risk Assessment was: If I fail and the brakes are spongy at the end then tow it to dealer and have them do it.
I did not do this to save $190 dealer charges but to get to know more about the car.
The brake fluid in the master cylinder and the one in the new can is almost same color. I couldn't tell the difference. Then why did I do it? Becos I had 31K miles and it was recommended at 30K service .
Tools needed:
Tools needed:
- 2 cans DOT 3 brake fluid (I got it from dealer. $6.50 each)
- 3/8 ID clear tube
- Empty water bottle and a catching pan and lots of rags
- Zip tie to strangle clear tube close to the bleeder
- Open end wrench size 8 for rear and 10 for front bleeder screw
- Covered the engine area and fender with big long rag just in case you spill drops of brake fluid
- I used 2 person technic one to push the brake pedal and one for bleeding screw.
- Order of bleeding is RR, RL, FR, FL.
- Simple physics: As you push open the bleeder. Close the bleeder after few seconds(30) and have the second person release the pedal
- As the fluid came out, since theres no color difference from old and new I let it flow until the fluid level in the master cylinder was between min and max and the stream had no bubbles
- Make sure to check the master cylinder often as you drain and refill it
- After doing each wheel I checked the Brake pedal and it was solid stiff that I couldn't push. This means no air on brake lines.
- After all the wheels are done took it for a test drive and pumped the brakes a few times slowly - no flooring first few times as I read this some where a while ago.
Ag02M5
Maintenance
08-12-03 06:14 PM
