AC / Heat issues
Sounds like your key fob was programed with climate system off. With car running and in park, adjust stereo,seat,steering wheel, climate control,mirrors to your liking. Then press and hold the lock button( the one on the drivers door) and then while holding the lock button, press and hold any of the 3 seat memory buttons until it beeps. That key fob is now programed to those settings. You can repeat the process for the other fob if you have 2 drivers. When you approach your locked car, it will adjust everything to the settings for that fob.
Make sure you do this with only 1 fob in the car, it won't work if both fobs are within range of the car.
I'm going see if this works. Thank you so much.
sojah
08-17-09 03:35 PM
