Need Electrical Help Please
Old 05-08-16, 05:34 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
Default Need Electrical Help Please
I'm running a Duracell 400W Power Inverter to charge my electric skateboard that needs 120W to charge. Like this:
Amazon.com: Duracell DRINV400 Black 400 Watt High Power Inverter: Automotive Amazon.com: Duracell DRINV400 Black 400 Watt High Power Inverter: Automotive
The specs on the Power Inverter is:
Input: 12 Vdc, 50A max
AC Output: 115 Vac, 60 Hz
400W 5 min max
320W continuous
DC Output: 5 Vdc / 2.1A
Neutral Floating
I connect this inverter straight to the battery and my skateboard charges fine with this. Our cigarette lighter tops out at 120W and can't charge my skateboard.
Is it safe to use this on the GS? What is the max that our alternator can handle? I should be good right?
Old 05-09-16, 08:36 PM
nobodycare
nobodycare's Avatar
Originally Posted by ItzFilyO
I'm running a Duracell 400W Power Inverter to charge my electric skateboard that needs 120W to charge. Like this: Amazon.com: Duracell DRINV400 Black 400 Watt High Power Inverter: Automotive
400W 5 min max
320W continuous
Neutral Floating
Run a dedicated line since the inverter requires 50a for the fuse. That's way too much for a cigarette lighter.
Old 05-09-16, 08:42 PM
ItzFilyO
ItzFilyO's Avatar
Finally!!! Someone answered!!! Thank you!!!
I am running it directly from the battery using the clamps. Is it ok? Do I need to keep my engine running?
Old 05-09-16, 08:55 PM
nobodycare
nobodycare's Avatar
Yes keep the engine running. Is this a temp thing or permanent? If permanent then I would wire it in as if you are doing an amp/stereo install.
Old 05-09-16, 09:55 PM
ItzFilyO
ItzFilyO's Avatar
No, just temporary. My skateboard only need 1 hr to fully charge it. So I won't damage anything if I keep my engine running right?
Old 05-10-16, 05:07 AM
jonathanz
jonathanz's Avatar
you won't damage anything, reason keep the engine running so it will charge your battery or else will drain your battery.
Old 05-10-16, 08:03 AM
ItzFilyO
ItzFilyO's Avatar
Okay that should do it. Thank you all!!!!!!!
Jeremyrome
12-12-14 10:43 PM
JJaySilver
12-20-13 12:11 PM
RuffinoJ
Performance & Maintenance
11-14-13 07:33 AM
5gears-IS
Great Deals
03-15-08 06:08 AM
Lexucan
07-03-06 02:04 PM
Quick Reply: Need Electrical Help Please
