Need HELP with spacers for RSR Super Downs..
Old 09-08-15, 08:22 PM
DavidArmas
DavidArmas's Avatar
Default Need HELP with spacers for RSR Super Downs..
I just bought the RSR super down springs and need help buying spacers. I am going to keep my STOCK WHEELS...I have seen post about people with these springs and 20mm all around and some with 20mm in rear and 15mm in the front.
I want to have the car as flush as possible without rubbing. I also would like to know about the Cons, if any about spacers. Hopefully I can get feedback from people that already have this set up.
If you have this set up and are happy with your spacers please post link where to buy the spacers.
And do they have to be Hub-Centric or something like that because the last thing I want is for the car to shake or anything like that.
P.S. I have no clue about spacers which is why I am asking for help! Thanks in advance!
Old 09-09-15, 04:06 AM
DUFF Ace
DUFF Ace's Avatar
I have tanabe nf's and did 15mm front and 20mm rear spacers with stock wheels. Looks perfect and no rubbing
I got mine from a local dealer here in Tampa but sell on Club Lexus. Many others have them with no complaints. I think the name of the company is SRR
Old 09-09-15, 04:53 AM
DavidArmas
DavidArmas's Avatar
Ok thanks man!! Any link or anything? And is 60.1 for the hub sound correct? Hopefully i can get them from there because I live in orlando... thanks again!
Old 09-09-15, 07:07 PM
DaPope10
DaPope10's Avatar
Hey Duff,
I am also in Tampa and looking the 15mm and 20mm spacers - where did you get them from?
Old 09-11-15, 11:02 PM
jayemko
jayemko's Avatar
I have this setup, zero regrets. Details:
FSport AWD, RS-R Super Downs, Ichiba 15mm front spacers, 20mm rear spacers. Bought the spacers from Amazon.
I also added Figs Rear Upper #2 Arms and after full alignment rear is aligned perfect and fronts very slight negative camber.
Steering wheel turns lock to lock without rubbing, myself with a passenger no rubbing either, but 3 rear passengers and 3 suitcases in the trunk = BAD. Sounded like the rear end was gonna fall out and had some tire pieces stuck to the rear doors; it's what I get for offering to shuttle to the airport.
Since I want to be able to carry rear passengers, I will be rolling the fenders and adding supplementary air bags in the rear to level out the car when/if I have rear passengers.
Buy the spacers. Without them, it's painfully obvious that you lowered your car. With them, the car actually looks like it should have from the factory.
Ichiba Version II V2 Wheel Spacers 15mm WS-5511460A https://www.amazon.com/dp/B007ZGCUUU..._Wa88vb4WQSV4D
Ichiba Version II V2 Wheel Spacers 20mm WS-5511460B https://www.amazon.com/dp/B007ZGCVIG..._Ab88vb2HN08ND
UCLAJimmy
01-22-12 09:00 PM
Sceptre
10-22-09 04:37 PM
hurricane
05-18-08 12:53 PM
SloGS400
11-11-07 11:27 AM
Quick Reply: Need HELP with spacers for RSR Super Downs..
