Lower grill removal question
For those that have done the lower grill swap on the non f sports I have a question. I was able to look up the DIY for the upper grill removal but for the lower grill did you approach it from the top after you removed the upper grill or did you go from underneath the car?
Thanks
Thanks
If u don't remove the bumper then u have to do it from the bottom. There is no way u can access the lower grille from the top because the bumper support and foam will be in the way.
Twisties88
04-19-13 06:19 PM
