Staggered wheels on AWD
I did a lot of search and found different opinions, but what I'm looking here is to see if anyone on here has 4thGS with AWD system and runs staggered wheels and if any issues or concern have arise?
Thank
Thank
Yes, the staggered setup has the same diameter all around, it's just wider in the back.
That what I found that diameter should be the same and increase from OEM wheels should not be more then 3%, the tire sizes I will probably go with are only 0.3% increase over stock and the same in diameter. How about a wider wheel in the back, will it cause issues, should I get the same wheels and just wider tires on the back or it is ok to have the wider wheel in the back.
Thanks!
Thanks!
StealthAWD
Wheels, Tires & Brakes Forum
05-29-07 07:49 PM
StealthAWD
05-24-07 08:11 PM
