Tapping Parking light wire for Fog Light install
I know others have tapped the parking light wire from the engine bay for their fog install. But I would like to tap this wire from inside the car (for extra protection of exposed wires from the element).
Does anyone know where it is? Preferably on the driver side of the car maybe near the fuse box. Thanks in advance.
Ok, I think it's in here somewhere, need to get out my voltmeter:
2013 Lexus GS 350 DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts black (60A) + driver dash fuse box, white 1 pin plug (5E), pin 1
Second 12 Volts blue (80A) + passenger dash fuse box, wht 1 pin plg (4E), pin 1
Starter purple (SS1), green (SS2) - Engine Switch, black 10 pin plug, pins 5 and 1
Also found purple - green (-) at the Certification ECU behind the glove box, white 30 pin plug, pins 28 and 30.
Second Starter lt. green + Certification ECU behind glove box, white 18 pin plug, pin 5
Ignition black + Certification ECU behind glove box, white 18 pin plug, pin 9
Also found black (+) in the passenger kick, blue 22 pin plug, pin 5.
Second Ignition black + Certification ECU behind glove box, white 30 pin plug, pin 6
Third Ignition N/A
Accessory black + Certification ECU behind glove box, white 30 pin plug, pin 4
Second Accessory N/A
Third Accessory N/A
Keysense N/A
Data Bus yellow (RX), white (TX) data Engine Switch, black 10 pin plug, pins 8 and 7
The immobilizer light is lt. green at the Certification ECU behind the glove box, white 30 pin plug, pin 18. The IMO - IMI wires are pink - lt. green in the driver kick, white 64 pin plug, pins 35 and 36.
Can Bus High green data data link connector, black 16 pin plug, pin 6
Can Bus Low white data data link connector, black 16 pin plug, pin 14
Can Bus Sw N/A
Power Lock use factory alarm arm
Power Unlock use factory alarm disarm
Lock Motor green 5 wire driver dash fuse box, white 48 pin plug (5C), pin 9
Driver Unlock Motor blue 5 wire driver dash fuse box, white 48 pin plug (5C), pin 10
Passenger Unlock Motor lt. green 5 wire driver dash fuse box, white 48 pin plug (5C), pin 12
Parking Lights (-) black - Body ECU, white 30 pin plug, pin 30
The Body ECU is attached to the right side of the driver dash fuse box.
Parking Lights (+) green + driver kick, harness to rear
Hazards pink - hazard switch, white 16 pin plug, pin 9
Turn Signal (Left) yellow + driver dash fuse box, white 48 pin plug (5C), pin 5
Turn Signal (Right) green + driver dash fuse box, white 48 pin plug (5C), pin 2
Headlight lt. green - Body ECU, white 30 pin plug, pin 29
AutoLights red (interrupt to turn off autolights) - Body ECU, white 30 pin plug, pin 28
Reverse Light red + driver kick, harness to rear
Left Front Door Trigger red - driver dash fuse box, white 48 pin plug (5C), pin 44
Right Front Door Trigger red - dr dash fuse box, rear, wh 64 pin plg (5A), pin 33
Left Rear Door Trigger green - Body ECU, white 18 pin plug, pin 3
Right Rear Door Trigger green - Body ECU, white 30 pin plug, pin 6
Dome Supervision lt. blue - driver dash fuse box, rear, white 64 pin plug (5A), pin 27
Trunk/Hatch Pin pink (without power trunk opener and closer) - Body ECU, white 30 pin plug, pin 19
The Body ECU is attached to the right side of the driver dash fuse box. On vehicles with power trunk opener and closer, it is gray (-) at the luggage closer motor in the left side of the trunk, white 26 pin plug, pin 20.
Rear Glass Pin N/A
Hood Pin gray - driver dash fuse box, white 32 pin plug (5D), pin 28
Trunk/Hatch Release yellow - Body ECU, white 28 pin plug, pin 8
Trunk Release Motor black (without power trunk opener and closer) 5 wire passenger dash fuse box, white 32 pin plug (4D), pin 18
Fuel Door Release (unlocks along with driver door)
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm gray (driver door key lock) - Driver Door Module, white 24 pin plug, pin 16
Factory Alarm Disarm purple (driver door key unlock) double - Driver Door Module, white 24 pin plug, pin 24
Disarm No Unlock Smart Key and ignition
Trunk Alarm Shunt lt. blue (trunk key cylinder) - passenger kick, white 67 pin plug, pin 24
Tachometer gray ac data link connector, black 16 pin plug, pin 9
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal N/A
Fuel Pump blue + driver kick, harness to rear
Rear Defroster black - passenger kick, gray 22 pin plug, pin 3
Mirror Defroster (CAN bus)
Left Front Heated Seat pink + driver kick, white 67 pin plug, pin 34
Right Front Heated Seat white + passenger kick, white 67 pin plug, pin 47
Speed Sense lt. blue ac radio, wht 59 pin plug, pin 56 or driver kick, wht 26 pin plug, pin 25
Brake Wire red + brake switch, white 5 pin plug, pin 2
Parking Brake (electric parking brake)
Horn Trigger pink - driver dash fuse box, white 32 pin plug (5D), pin 10
Wipers gray (LO), pink (HI) - driver kick, white 26 pin plug, pins 1 and 15
Left Front Window (Up/Down) use factory alarm arm/disarm
Right Front Window (Up/Down) see left front window
Left Rear Window (Up/Down) see left front window
Right Rear Window (Up/Down) see left front window
Sun Roof (Open/Close) use factory alarm arm/disarm
Sun Roof (Limit/Close) N/A
Memory Seat 1 black - Driver Door Module, white 26 pin plug, pin 22
Memory Seat 2 lt. blue - Driver Door Module, white 26 pin plug, pin 23
Memory Seat 3 purple - Driver Door Module, white 26 pin plug, pin 24
Radio 12V blue + radio, white 59 pin plug, pin 17
Radio Ground white/black - radio, white 59 pin plug, pin 12
Radio Ignition gray + radio, white 59 pin plug, pin 16
Radio Illumination green (parking lights), white (dimmer) +,- radio, white 59 pin plug, pins 14 and 13
Factory Amp Turn-on (MOST bus)
Power Antenna N/A
Left Front Speaker (+/-) pink - red (door); white - red (dash) +,- amplifier, white 30 pin plug, pins 4 and 19; 12 and 27
The amplifier is in the right side of the trunk.
Right Front Speaker (+/-) lt. green - blue (door); red - pink (dash) +,- amplifier, white 30 pin plug, pins 5 and 20; 13 and 28
Left Rear Speaker (+/-) black - yellow (door); lt. green - blue (surround) +,- amplifier, white 30 pin plug, pins 14 and 29; 10 and 25
Right Rear Speaker (+/-) red - white (door); black - yellow (surround) +,- amplifier, white 30 pin plug, pins 15 and 30; 11 and 26
Center Channel (+/-) yellow - black +,- amplifier, white 30 pin plug, pins 7 and 22
Subwoofer (+/-) red - white +,- amplifier, white 30 pin plug, pins 6 and 21
Aux. Audio Input Left (+/-) black - red +,- radio, white 16 pin plug, pins 8 and 15
Aux. Audio Input Right (+/-) white - red +,- radio, white 16 pin plug, pins 7 and 15
RSE Video (+/-) red - white (rear view camera video) +,- radio, white 59 pin plug, pins 18 and 19
RSE Audio Left (+/-) N/A
RSE Audio Right (+/-) N/A
Satellite Radio 12 Volts N/A
Satellite Radio Ground N/A
Satellite Radio Ignition N/A
Satellite Radio Antenna N/A
Satellite Audio Left (+/-) N/A
Satellite Audio Right (+/-) N/A
Item Size Depth Location
Headunit irregular center of dash
Left Front Speaker 7.0 or 6.6 x 9.8 left front door
Left Front Tweeter 3.5 left front dash
Right Front Speaker 7.0 or 6.6 x 9.8 right front door
Right Front Tweeter 3.5 right front dash
Left Rear Speaker 6.2 or 6.6 left rear door
Left Rear Tweeter 0.9 (tweeter); 3.5 (surround) left rear door; left rear deck
Right Rear Speaker 6.2 or 6.6 right rear door
Right Rear Tweeter 0.9 (tweeter); 3.5 (surround) right rear door; right rear deck
Center Channel 3.5 top center of dash
Subwoofer 9.8 top center of rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner (built into radio)
All Products
Third Ignition N/A
Third Accessory N/A
Keysense N/A
Can Bus Sw N/A
Rear Glass Pin N/A
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal N/A
Power Antenna N/A
Left Front Headrest
Left Rear Headrest
Right Rear Headrest
audiovascu
02-28-11 08:05 AM
