squeeky brakes
Old 01-16-13, 10:55 AM
  #31
Dashin
Dashin's Avatar
Mine does also.
RWD F sport Dynamic handling
Dealer just replaced pads and rotors, problem not fixed.
Car has 800 miles on it
Old 01-16-13, 11:21 AM
  #32
wlmngtn310
wlmngtn310's Avatar
My brakes just recently started squeeking. It's annoying as hell! I'm at 9.7K miles on my Fsport. Ill be going to the dealer soon for my 10K service so ill bring it up to them, then.
Old 01-16-13, 01:29 PM
  #33
SoCal1984
SoCal1984's Avatar
Originally Posted by djpeakSD
LOL, I stomped on my brakes at 80 MPH on the way home from the dealership! I guess i'm not the best at breaking things in.
LOL . . . . Always a good test while in the middle of a test drive. . . . . . in a 30 MPH zone none the less . . . .
Old 01-17-13, 05:57 AM
  #34
PLAYTYM
PLAYTYM's Avatar
Originally Posted by mso4
I'm not sure if any of you guys break-in your brakes (bedding) but this is what I did with mine. I'm not sure if it's absolutely required but I've done this on my Corvette, BMW, and an Accord and none of them squeal anymore.
Some brake manufactures simply suggest easy braking for the first few hundred miles (similar to the Lexus manual and its suggested break-in period). So I was hesitant to do this with my brand new Lexus. But then I thought I always do this whenever I install new pads and rotors so this should be no different.
We'll see how things turn out. Right now I barely have 500 miles and I'm planning to do a second set of bedding tonight.
http://www.stoptech.com/technical-su...ake-pad-bed-in
http://www.stoptech.com/technical-su...-system-bed-in
The instructions below are more clear:
http://www.zeckhausen.com/bedding_in_brakes.htm
Never heard of this and have been a "hobby" mechanic all my life. It makes sense...love it!
Old 01-17-13, 08:21 AM
  #35
maxwebr
maxwebr's Avatar
great..so when the heck are they going to address the F-sport models! getting really pissed that it has been more than 6 months with no solution. I have a service appt Monday, so I am going to ask again.
Old 01-17-13, 10:11 PM
  #36
mso4
mso4's Avatar
Well even after doing the bedding my brakes started squealing at 5k miles, now it has 7k miles and it's getting worse. I'm going to redo the bedding to see if that helps. Theoretically it's possible that the original 'layer' got rubbed off so we'll see if re-bedding make any difference.
I'm pretty sure changing pads and rotors won't make any difference.
Old 01-17-13, 11:02 PM
  #37
G369
G369's Avatar
LSB is out for GS350 and GS350 F-Sport brake squeak
Old 01-21-13, 08:58 AM
  #38
tcarilli
tcarilli's Avatar
Last week I posted a problem with my GS350 2013 brake noise and forgot to mention that it was a F sport model, it that makes a difference.
TC
Old 01-21-13, 08:33 PM
  #39
dseag2
dseag2's Avatar
5700 miles on my F Sport with no squeaky brakes but I will keep the TSB info handy.
Old 01-21-13, 11:43 PM
  #40
peteharvey
peteharvey's Avatar
After 40,000 miles, my front rotors are now down to 28mm thick, with the min recommended at 27mm, so I purchased a pair of brand new genuine GS front rotors at 30mm thick.
Purchased brand new genuine GS front pads, and I was told to purchase brand new GS front brake pad shims too.
The genuine shims cost more than the genuine pads!
At first, the brakes were whisper quiet.
Now, several weeks later - they're squealing again; I will have to change the brand of pads next time.
However I do remember that last time when I removed the pads, and sandpapered the surface of the pads, and tidied them up, the squealing did stop for a long time until the pads were totally worn out, and the wear indicator stepped in, so maybe I will just service these brand new pads first with some sand paper...
Old 01-22-13, 07:37 AM
  #41
SoCal1984
SoCal1984's Avatar
What is the LSB # for the F-Sport. I can only find the one for the Standard and luxary model.
Old 01-22-13, 07:55 AM
  #42
maxwebr
maxwebr's Avatar
In for my 10000 mile service. They do have a fix now for the F-sport RWD. New pads are on order and should be in Thursday. I hope to have this issue resolved Friday. Keep everyone posted.
Old 01-31-13, 07:20 AM
  #43
Rexus300
Rexus300's Avatar
Does any one have the TSB number or link copy so I can get it printed out. My brakes make a grinding sound for the first few brakings when the car is taken out of garage in morning or after work. Then it goes away. Did not have this before. I have the GS350 F-Sport AWD 11,000 miles.
Old 01-31-13, 07:37 AM
  #44
1111GS
1111GS's Avatar
Originally Posted by jsch222
5100 milies on my non-Fsport and mine squeak every morning when I pull out of the garage.
I notice this same thing. At first, after I washed the car. I thought maybe the remained water. Then I still hear the noise in the morning, but it goes away as I drive/speed up. I'm going to need to pay more attention. Mine is at 4K now but I started hearing this a few weeks back. It hasn't bugged me enough to bring in but if it doesn't go away, I guess I will need to have it checked at 5K service. Mine is stock RWD Luxury.
Old 01-31-13, 12:49 PM
  #45
maxwebr
maxwebr's Avatar
ETA for new pads is 2/6. so still a couple weeks out before I am be sure this is fixed for good.
Quick Reply: squeeky brakes
