Wheel Hub Bearing
assuming you are changing out the front, this video should be helpful. different lexus but same general concept.i did mine last month and it was fairly easy, should take no longer than 45 minutes. i dont remember the exact detail as in bolt sizes but basic instructions. take the wheel off. take apart the brakes. unbolt the caliper(2 bolts, i believe are 17mm). unplug the sensor wire. unbolt the 4 bolts holding on the hub assembly. take off the hub assembly and put in the new one. vise versa for installation. hopefully i didnt skip a step, this is all from memory. good luck.
Tigger240
07-03-17 09:19 AM
