4GS wheels on 3GS(2010 450h)
Added the spacer in the rear to have a more flush appearance. Shaved rears, rolled fronts, with some camber all around.
When I get new tires, I will probably do a mild stretch for the front and rear (225front/255rear staggered f-sports) and swap a 25mm to the rear and the 20mm to the front. I am hoping I'll have enough clearance on the front fender to do full lock to lock turns (on hard turns, my wheel rubs against the fender).
Just a heads up, if you run the OEM tires from the 4g f-sports (IIRC 235/40/19F 265/40/19r), your running a slightly larger tire than stock. I think its about an inch larger in diameter. If your slammed, you will rub.
When I used to be lower... :x
@boss - lowered on BCs with swifts. Haven't ridden in other lowered 3gs so cant compare the ride quality, but if I was to do it all, id look into KW's (the is250/350s SHOULD fit, but do some research) or 326power coils. I hear the 326power's ride nice even when slammed. The ride on good roads is superb; bumpy/dips/railroad tracks not so much.
@wicked - Thanks! Stance isn't quite where I want it, but its always the question of play with spacer or new wheels Don't think I'll go 20s. They fill out the wheel wells nice, but . Maybe when I have more time on my hands I'll play around with some wheels/tire/alignment settings.
JDKane527
03-24-09 07:23 PM
