2006 GS300 86k Leaking Front Cover $3,500
Hi all,
Took my Lexus into the dealer for an oil change. I have 86,000 miles on it. The dealer said my "Front Cover" is leaking pretty heavily and they said it will cost $3,461 to repair because they have to drop the engine and significant labor is involved. I need to call around all though I don't know of other reputable shops in my area that will be any more affordable. I assume I need to bite the bullet and get this repair done at some point.
Any advice?
Thanks
Any advice?
Thanks
It's pretty involving. I had my done a couple months ago. They will reseal the oil pan, front timing cover, new seals, new valve cover gasket, and coolant and some other things.
Maybe take it to and independent Lexus shop. 3rd party shop may not use the same "gasket in a tube" that Lexus uses.
Was the engine ever rebuilt for the carbon issue? If so maybe the tech didnt seal it up thoroughly.
Front cover? I would go back to the dealer and tell them what exactly is leaking. Theres a timing belt cover, behind you would have crank that has a seal to it, camshafts, water pump etc.
I may suspect the front crankshaft seal
I got the same problem(i have the same year too), timing cover leak, cost CAD 4000, and they said they could offer me a discount.
But to be cost effective though, i just top up once between a oil change so i don't have low engine oil problem, i don't think it's worth spending that much for a small leak unless you're planning to drive the car for another 10 years....especially when it's known for carbon build up
Just spend the money for a new gs 2-3 years later
It's the timing cover. They said it's what holds the timing chain. The engine has never been rebuilt. My car is in very good shape and well maintained only 86,000 miles. So frustrating. I am going to check an independent shop. They said it's leaking pretty heavily (whatever that means). So will see what the independent shop says.
I'd take it to a high quality independent that deals with Japanese vehicles, they should have experience with these sorts of issues. And like someone else said, if it isn't leaking too badly, I'd just let it go and check the oil level frequently...then trade it in a couple years down the road (or sooner).
Maybe try this and some higher grade viscocity oil. Also if your running synthetic run regular oil and change your oil more often.
https://www.amazon.com/BlueDevil-Pro.../dp/B000OAEN7C
