07' gs 350 awd engine vibration.
hi all,
im not sure if there is a post on this subject,.. about a year ago i notice this vibration and took it to my local lexus shop they stated that my engine mount is bad. bought the mount from lexus and change and vibration is still there...,my question is am i the only one that is having this engine vibration problem or this a common problem for the 06-11 awd.? any info will help. thank you
When was the last time you replaced your spark plugs? Are you lowered?
Rarely do 3GS GS350 motor mounts go out, unless you're a really aggressive driver. On higher mileage AWD the front cv axles can wear and cause slack in the transmission causing a vibration at idle.
You can see if the dealer is willing to put the car in idle on a rack and have a tech pin point exactly where the vibration is coming from.
hi all,
RXGS
11-18-11 05:47 PM
hyperopt
09-07-04 09:16 PM
