Door interior trim removal
Is there a 'how to' somewhere for the removal of the door card / interior trim. Someone has kindly creased my door with their carelessness and I need to get inside to try work the crease out. I have looked PDR kits but its not really a wide dent, just a crease made by another door so a bit rolling form the inside ought to sort it.
roll the window down, in the door handle there is a screw colver, remove it, the second screw is located under the door light inside the bottom pocket. pull the light out and the screw will be inside, the rest is all clips. be careful working the clips they like to brake. pull the clips OUT OF THE METAL DOOR, not out of the door card. work you way from one side of the door card/widnow to the other, and then lift.
