Just installed Sage 25mm RCA blocks on 08 AWD
Old 06-24-15, 01:30 PM
Anthony3GS
Anthony3GS's Avatar
Default Just installed Sage 25mm RCA blocks on 08 AWD
I've been snooping around on these forums forever now and finally made an account!
Just bought the car 2 weeks ago and decided to go with a 20 inch staggered setup. I emailed Peter about the 25mm RCA's and just received them Monday. Thanks Peter! Anyways here's my car!
Attached Thumbnails Just installed Sage 25mm RCA blocks on 08 AWD-img_20150624_114205.jpg   Just installed Sage 25mm RCA blocks on 08 AWD-img_20150624_114226.jpg   Just installed Sage 25mm RCA blocks on 08 AWD-img_20150624_114218.jpg   Just installed Sage 25mm RCA blocks on 08 AWD-20150624_120744.jpg
Nova6682 (02-26-24)
Old 06-24-15, 02:01 PM
alSpeed2k
alSpeed2k's Avatar
It looks great! Any side profile "Before" shots?
Old 06-24-15, 02:11 PM
cdub350
cdub350's Avatar
Few Very Curious Q's:
Any ride difference?
Why did you go this route over springs/coilovers?
Can you expect same issues from lowering (camber, axle issues, rubbing)?
Old 06-24-15, 11:55 PM
Anthony3GS
Anthony3GS's Avatar
I'm sorry I don't have any before shots of the side view. It was pretty hideous though...the front sat higher by an inch.
Old 06-25-15, 12:02 AM
Anthony3GS
Anthony3GS's Avatar
The ride quality is less floatier feeling. I can definitely feel the road more now, but other than that it feels pretty much the same. I went with rca's because I feared the vibration everyone was talking about after lowering their cars on springs or coils. It was definitely the look I was looking for. The front sat higher by an inch, I wanted it a tad lower than the rear. As for rubbing, I do get slight rubbing turning the wheel fully while doing u turns or backing out of driveways. It's only the plastic lining though..nothing a heat gun won't fix. 20x8.5 35 offset in the front btw.
Old 06-25-15, 04:35 AM
IXI187IXI
IXI187IXI's Avatar
not to mention if you want to go lower you can probably do f sport springs and not notice too much of a difference
Old 06-25-15, 08:48 AM
Anthony3GS
Anthony3GS's Avatar
You really think so? I might take that into consideration!
Old 07-01-15, 07:10 AM
Sleeper97
Sleeper97's Avatar
Car looks good, question for you. Are you running a spare tire? if you are, does the spare clear with 25mm RCA blocks?
Old 07-01-15, 08:49 AM
uberEJ
uberEJ's Avatar
car looks great on the RCA blocks.
any lower you may get vibrations... RCA blocks still change the angles of the axles. its a hit or miss with front RCA blocks as to whether you get vibrations or not. its just less likely you would get vibrations.
and on a side note it will not change the amount of travel/dampening of the shocks meaning you will still have the same amount of lean around a corner. so i don't suggest hooking your car around corners unless you want your fenders pulled in lol
Old 07-02-15, 09:05 PM
Mrcam216
Mrcam216's Avatar
Looks good. Question, what size tires are you running? I have a set of 20's, +35 offset on the front and back. Front tires are 225 35 and rears are 255 30. But the tires are not sitting flush sight the side of the wheels. But also, did you have any issues installing the front and rear RCA's? I purchased the front but was unable to get the part off once I took the two screws off to put them on.
Thanks in advance
Old 07-08-15, 01:25 PM
cloud777x
cloud777x's Avatar
I have fsport springs on my car. 2 finger gap front 3 finger gap rear... I wonder of the RCA will eliminate the fender gap (period). or will it be too low?
LNXT200
NX - 1st Gen (2015-2021)
04-17-19 12:52 PM
kh4nh
06-09-13 03:38 PM
mikedozz
05-20-09 05:17 PM
stvincent
Suspension
44
02-03-09 11:17 PM
Quick Reply: Just installed Sage 25mm RCA blocks on 08 AWD
