Wheel hub assembly
Old 07-31-14, 01:48 PM
Iknowspurg
Iknowspurg's Avatar
Default Wheel hub assembly
I Have been looking and looking for a DIY for wheel hub assembly replacement. Is this job very difficult ? Does it require any specialized tools? Job difficulty on a scale 1-10.
Thanks.
Also, besides Sewell , where would u buy the wheel hub assembly?
Old 07-31-14, 02:08 PM
alchemist
alchemist's Avatar
Rock Auto or ebay might have it
Old 07-31-14, 04:38 PM
Iknowspurg
Iknowspurg's Avatar
ok thanks. any experience with this DIY?
Old 07-31-14, 08:00 PM
alchemist
alchemist's Avatar
Not that bad. Basically after getting axle nut off and tie rod you are home free:
https://www.clublexus.com/forums/rx-...p-by-step.html
And
https://www.clublexus.com/forums/es3...-pictures.html
Old 08-02-14, 03:42 PM
Iknowspurg
Iknowspurg's Avatar
This looks to involved for me............................ Since I am replacing the hub assembly, I guess , like u said, just get the axle nut and tie rod off and I am home free. ............. I wonder how much a shop would charge for this?
Old 08-06-14, 06:48 PM
Asav
Asav's Avatar
Do it! I have said that every time I needed to do something, then I look around here and get some good info to tackle it. You will feel better about leaning a tad bit more about how your car is set up. That's what makes the forum great! Trust me some stuff I would not even think of attempting so I know hw you feel, but this is worth tackling.
Old 08-25-14, 06:26 AM
Iknowspurg
Iknowspurg's Avatar
Default Ok ok
Does anyone know exactly what tools are required??
Old 08-25-14, 08:26 AM
BinaryJay
BinaryJay's Avatar
At this point in my life I would bring it to a shop to get done and go have a nice lunch.
Old 08-25-14, 08:37 AM
alchemist
alchemist's Avatar
special tools or all tools?
Old 08-25-14, 09:34 AM
Iknowspurg
Iknowspurg's Avatar
All tools. I have access to a number of tools but once I tear down everything over the weekend I won't have access. The tools will be at work and will be locked up.
Old 08-25-14, 11:28 AM
alchemist
alchemist's Avatar
Look at that first link up top. For special tools, you need a specific socket for Axle nut (30mm and has to be 12 pt not 6pt). AND you need tie rod end remover - can get at harbor freight. If you are buying entire hub assembly and not pressing new bearing in, you dont need a press.
Old 04-02-15, 07:44 AM
LovezLexus
LovezLexus's Avatar
I'm about to change the hub assembly on my 450h. I could do a picture DIY if requested, but I am currently encountering a problem. I took the rotors and caliper off, but the assembly won't come out. There were 4 screws and the ABS sensor that I took off. What do I do now? I'm looking at it and I don't think I need to remove the tie rod and I can't find an axle nut. I thought our cars don't have an axle nut. Any help?
ArmyofOne
04-16-19 05:31 AM
THoon
03-19-18 10:59 AM
river
RX - 1st Gen (1999-2003)
04-03-16 10:03 AM
M K S
02-11-16 06:43 AM
little2576
09-05-15 12:23 PM
Quick Reply: Wheel hub assembly
