Changing Transmission Fluid ***DIY w/ pics***
#92
Maybe they changed the size of the WS Fill bolt but mine was more like 24mm than 20mm as tested with my 24mm deep socket. Ordered a 24mm low profile oil change socket and will see how that works as there's not a lot of clearance in that area.
edit: 24mm low profile oil filter socket worked perfectly with standard 3/8 ratchet and breaker bar.
#93
What if I just measure exactly what came out and pump new fluid back in. Will I have to still do the OBD and all that shifting? I have over 177,000 miles on my 2007GS 350.
#95
#96
#97
Ii had front wheels on the ramp.. 15 inches uplift. Didn't touch the shifter as we... Its 2007 gs350 AWD with 48000 miles... I only got 3 quarts os WS atf. Looks like i need to get 2 more...
#103
Lexus service docs say that drain and level check bolts should be torqued to 15lb/ft, and fill plug should be torqued to 29ft/lb. I got all three bolts out with a standard socket wrench, but removing the fill plug would've been easier with a breaker bar.
#104
Ok I did it. Boy was it tiring pumping all that fluid back in. The only problem I can came across was not able to remove the level check bolt because I couldn't find one that would fit correctly. Does anyone remember what Allen key size the check level bolt takes?
#105
Either 8mm or 6mm. I'm fairly sure it's 8mm.
