20mm spacer all round on Stock Rims ??????
Hi guys has anyone used or does any one know if 20mm spacer all round on Stock Rims rub in any way or should I go 20mm on the rear and 15mm on the front ???? I would rather 20mm all round but don't want rubbing
I have 20mm all around, lowered on Tanabe NF springs and there is some rubbing up front on large bumps or when I have passengers in the car. Nothing major but it does rub. Just a bit.
Stock Lexus wheels... 15mm spacer front, 20mm spacer rear
Tires: 245/45/18
Slight rub in rear on big dips and 4 people in the car. Otherwise, no issues.
The tires are slightly larger than OE, so with OE size I think there would be no issues under any circumstance.
hello. so far this is the best configuration witch the spacers. 15MM front and 20MM back.I have 2007 GS350 witch 235/45R18. this rims going from 2012 GS350. I will instal ichiba wheels spacers.
What brand do you have?
