iVic 5i Mounting Location in 07 GS350
Old 02-13-14, 04:07 PM
rominl
exclusive matchup
rominl's Avatar
yes i know exactly what you mean. same with the 2is, it has to be at certain angle otherwise it hits here and there
but this is VERY VERY good to know, i think this is a great location for sure
Old 02-14-14, 07:11 PM
welderant0
welderant0's Avatar
Originally Posted by james0076s
Yeah there enough space but just barely. You have to find the right angle so it fits without having to crush the ivic or bending the plastic cover
Thanks man! I looked under there but it didnt look like it would fit. I guess I know what I will be doing tomorrow! I read somewhere that it may not work if you dont have the updated navigation DVD. Is there any truth to that, that you know of?
Old 02-14-14, 08:08 PM
james0076s
james0076s's Avatar
You should be fine, my original navi dvd is still in there with he ivic with no problem. I would recommend that you mount the ivic (Velcro works wonders) and see how you will be mounting and angling the brains of the ivic to see if it closes properly, then run the cables and program and enjoy!
Old 02-15-14, 01:11 PM
welderant0
welderant0's Avatar
Got it installed today but can't get the confirmation beeps when trying to program it. Has anyone had this problem? It connects to my head unit with no problem but the ivic display does not come up. It displays some messages on the screen put the ivic screen never comes up! Of course there is no tech support on the weekend!
Old 02-15-14, 05:09 PM
rominl
exclusive matchup
rominl's Avatar
on your navigation system, press on INFO (on the left), do you have beeping off? make sure it's not off
and if you don't hear beeps, then it's not programmed correctly. keep on trying. read my review for more tips
Old 02-16-14, 04:11 AM
welderant0
welderant0's Avatar
You were right, my beep was set to off. The only thing is that even tho I wasnt getting the beeps when I was trying to program it yesterday, the yellow light never flashed like the programming steps said it would. What would happen if I unplug the cables on the ivic? Do you think this would be like a hard reset and then I could try to programming agian?
Old 02-17-14, 10:19 AM
welderant0
welderant0's Avatar
Finally figured out the problem today. I have to use the mode button on the steering wheel in order to get to to ivic interface. Thank you guys for the help and ideas.
Old 02-17-14, 11:42 AM
rominl
exclusive matchup
rominl's Avatar
oh sweet! glad you are figuring it out
but besides using the MODE button, you should also be able to use the DISC button on your radio. it should now cycle through the factory changer and ivic
HUSKERnKS
04-08-12 11:47 AM
GSspeed
05-12-08 11:15 AM
ste
01-11-08 06:07 PM
gs350hb
05-28-07 07:10 AM
Quick Reply: iVic 5i Mounting Location in 07 GS350
