The best tip/trick/diy/diagnostic tool ever
Old 06-07-14, 09:45 PM
  #91
justYnG
justYnG's Avatar
Interested in this product but I need to be able to turn off the tpms aka dummy light.
Old 06-07-14, 09:58 PM
  #92
YaMomma
YaMomma's Avatar
Then find the bad sensor and replace it, you can clear the error code and the light will go off but come back on after you have driven about 50 miles.
Old 06-14-14, 03:54 PM
  #93
smilepak
smilepak's Avatar
For those with Windows 8, have you tried this
http://lifehacker.com/5965889/how-to...e-in-windows-8
I bought it off Amazon the other day, received version 8.0 of the software. ANyone know if there is a newer version or a digital download version? I got no CD player on my WIndows 8 hybrid Laptop
Old 06-14-14, 04:39 PM
  #94
smilepak
smilepak's Avatar
Is this the latest version of the Global Tech Stream software used by this cable?
http://www.ft86club.com/forums/showthread.php?t=35530
Old 06-14-14, 05:32 PM
  #95
YaMomma
YaMomma's Avatar
Don't waste your time with a VM version of windows xp, there is a link towards the beginning of this thread which will show you how to properly install the software and drivers. I have it working fine on my 64bit windows 8.1 laptop.
I've never seen anything higher than 8.3 which is what I currently have installed. I didn't use the disk that came with my cable either due to it having an older version. Therefore the 9.1 should work fine and that's the latest version I could find on the internet.
People aren't having problems with the software it installs fine but if your drivers aren't setup properly it won't work.
Old 06-14-14, 06:57 PM
  #96
smilepak
smilepak's Avatar
thanks...
turned out, the CD that came with the cable is version 9.10.037 lol. And yet, they dont have native Win 7 support. Lol...
XP is out of support at this point..hahha
Old 06-15-14, 08:44 PM
  #97
snkepit
snkepit's Avatar
Just ordered me one. Thank you CL family
Old 06-18-14, 04:29 PM
  #98
smilepak
smilepak's Avatar
Got it setup and connected to my Dell XPS 12 under Windows 8.1 64 Bit using version 8.00.
I had some issue with 9.10 that came with the CD or online with getting the key to work.
Anyhow, other than some customization stuff like turn on and off DRL etc., what else can you do with this?
Old 06-19-14, 07:32 AM
  #99
blue00
blue00's Avatar
Diagnose and self test each ECU. Clear DTC codes in ECUs other than the engine/emissions control (OBDII). ie diagnose a warning light will cost you $100 when out of warranty and they will make sure to take an hour to do so. It takes less than 5 minutes with this tool.
Most people pay $50-$100 for a generic OBDII scanner, This software and cable does that AND accesses all of the Toyota proprietary ECUs. I consider it a very good investment if you care to know what the problems with your car are (when you get problems)
Old 06-19-14, 07:51 AM
  #100
uberEJ
uberEJ's Avatar
if you need to know your problems just go to autozone and get them to read it... its free
don't even need to spend money lol
but yes this is a good system to actually pinpoint and adjust systems.
Old 07-02-14, 07:33 PM
  #101
aleung3
aleung3's Avatar
finally got this software installed and hooked up to my car, but when I try to customize the light settings the window doesn't open. The only ones that seem to open for me is tilt, air conditioning, compass calibration, and seat...anyone else having this problem? I'm just wanting to turn off my DRL.
I have a 06 gs300, if that matters
Old 07-03-14, 09:11 AM
  #102
YaMomma
YaMomma's Avatar
Turning on/off DRL in an 06 works, that's what I have and I didn't have any problems with that menu. The options however are specific to the car and ECU, turning off DRL may not be an option for Canadian cars.
Old 07-06-14, 08:02 PM
  #103
snkepit
snkepit's Avatar
Tried to register tpms I got off ebay but didn't work. It would have worked if I had the ID number but they already have tires mounted now. Have not tried the DRL's yet.
Old 08-25-14, 08:17 PM
  #104
jkdsl1
jkdsl1's Avatar
Originally Posted by Htle83
Just an FYI, it can work on Win 7/8 with 64 bit/x64 OS'. I have it working on my Macbook Pro - Win 8 64 bit. It requires a little know how with the registry and slight adjustment to the install process.
That's great. Can you provide details?
Old 09-22-14, 05:41 PM
  #105
IcyBishop
IcyBishop's Avatar
Worked great to disable my DRL's. I haven't gone through the steps to set it up on my 64 lappy yet, but worked fine on my 32 bit one.
I didn't see where to disable the seatbelt chime within the software - does anyone know if it's in there for 2008s?
I know there's a button sequence to do it, but I just need to satisfy my curiosity
Quick Reply: The best tip/trick/diy/diagnostic tool ever
