any adjustments to door lock actuator
Old 11-28-12, 10:44 AM
yumseyo
yumseyo's Avatar
Default any adjustments to door lock actuator
Hi All, I own a 08 GS 350. It has a occasional noise at the right rear door lock actuator. The actuator has been replaced and has now gotten worse. Does anyone know if there are any adjustment to the linkages or ? at the actuator that might be too loose or too tight that would force the actuator to slip and cause a slipping "squeeling" noise on 1st application? If you manually operate the actuator with the switch several times the noise does not occur.
Old 11-30-12, 03:29 PM
morganc
morganc's Avatar
Maybe try shooting some silicone lube down it? Strange indeed, considering it's been replaced.
pernjiepoi
04-23-22 07:23 PM
musabbari
10-17-10 08:01 PM
Quick Reply: any adjustments to door lock actuator
