GS350 Fuel Tank Capacity
Old 02-13-12, 10:08 AM
NickL
NickL's Avatar
Default GS350 Fuel Tank Capacity
The manual states 18.7 gal (71L, 15.6Imp. gal)
I filled the tank to the max, drove until the warning light comes on and a bit more. The computer calculated range is 4miles before I refill. By this time, I've driven 310miles on the tank.
When I refill at the gas station, I'm only putting about 15.4gallon.
So my question is, did I drove my fuel tank all the way down and go by the 15.6Imp. gal rating? Or is there a 3gallon of reserve left that the computer did not account for making the fuel tank a 18.7gal capacity?
Old 02-13-12, 10:14 AM
JH48
JH48's Avatar
when the light came on, that mean you still got 2 or 3 gallons left
Old 02-13-12, 10:29 AM
IXI187IXI
IXI187IXI's Avatar
your car doesnt take into account the reserve. there was a thread a long time ago about members pushing the range limit and many have gone well passed the 0 mile range mark.
Old 02-13-12, 10:33 AM
NickL
NickL's Avatar
So the tank is a 15.6 gallon tank then?
Old 02-13-12, 10:36 AM
JH48
JH48's Avatar
more then 16 gallon
Old 02-13-12, 10:52 AM
Bushwack
Bushwack's Avatar
I recently traveled 529 miles on a tank (all freeway). I calculated 29.9MPG the old fashion way (mileage divided by gallons of gas purchased at fill-up. FWIW...the DIC had my mpg at 30.0). Put in 17.7 gallons (the last 45 miles was nerve racking staring at that darn indicator light). Therefore capacity is at least 17.7 gallons and I do believe the 18.8 capacity as stated is correct. There's no 'reserve' capacity. That's a fallacy. Light goes on about 2.5 gallons prior to empty.
BTW, it's a foolish thing to consistently wait until you're at 1/4 of a tank or less. You damage the fuel pump.
Old 02-13-12, 11:07 AM
NickL
NickL's Avatar
hmmm...that doesn't make any sense then. Because the pump is only charging me for 15.4gallon.
Old 02-13-12, 12:22 PM
rominl
exclusive matchup
rominl's Avatar
15.4 gallon you pumped in, but the are still about 2 gallons reserves in the tank when the light on your dash comes on
Old 02-13-12, 12:29 PM
NickL
NickL's Avatar
Hi Rominl,
I guess I'm following your track. I've been on the Acura-Zine forum for over 10 years now Lexus forum.
The light came on for a while. The gauge is almost at the bottom of the tick. Can it go beyond that?
Anyway, so the tank capacity is 18.7 gal and not that 15.6 number.
I have a habit of using the fuel all the way down. I've been doing this with my TL-S for almost ten years and there was no fuel pump issue with it.
Old 02-13-12, 12:41 PM
GS350Lexus
GS350Lexus's Avatar
Originally Posted by NickL
Hi Rominl,
The arrow doesnt go below LOW point, but when the light comes on you still have 2-3 gallons in reserve. Its k to take it to the light before fill up you won't damage fuel pump, but make sure not to drive too long on the light. Lets say the fuel gauge has 1-10 1 being on the light and 10 being full. The calculation from 1-10 is the 15.5 gallons of gas, so when the arrow is at 1 you still have 2-3 gallons but the gauge won''t go below 1. Hopefully u understand
Old 02-13-12, 12:43 PM
JH48
JH48's Avatar
Hi Rominl,
the light gone on that just give you signal the gas almost empty. It doesnt mean nomore gas, so yes it will be 2 or 3 gallon left
Old 02-13-12, 01:34 PM
rominl
exclusive matchup
rominl's Avatar
Hi Rominl,
a lot of people went from acura to lexus i see
i have gone below "0 range" once and some people posted they drive 30 miles after 0 range and still got gas left. not saying it's good though
Old 04-22-13, 02:14 PM
Lexus88
Lexus88's Avatar
thread revival... I have a gs430... i believe the fuel tank is rated about the same size... i always push the limits on my gas tank because i'm lazy to refill on gas... i always push it well past when it says I have 0 miles left... seems the gas light always comes on after using about 13-14 gallons... Last night i drove it till the car was about to be out of gas... when you step on the gas, you can feel little skips in the throttle... i knew it was about to be out of gas because i actually ran out of gas on my last car and it did the same thing before dying out... lucky there was a gas station just right there.. My tank filled up at approx 17.1 gallons....
Old 04-22-13, 04:55 PM
rominl
exclusive matchup
rominl's Avatar
that's a good way to potentially damage your fuel pump
b2884987
RX - 1st Gen (1999-2003)
02-10-17 05:11 PM
dchar
10-29-13 10:09 AM
keycard198
12-31-09 03:58 PM
shyishguy
11-27-07 07:53 PM
1seeker1
ES - 5th Gen (2007-2012)
16
12-20-06 04:20 PM
Quick Reply: GS350 Fuel Tank Capacity
