Radio Interference w/ Rear Defroster Enabled
Good Morning CL...
I have a MAJOR issue with my radio. I searched the forums for this and only found 1 post matching my issue...and no fix was found.
Whenever I turn on the rear defrosters on my 07' GS350 | NAV | ML the FM radio frequency goes out, and I only get static. This "only" happens when I enable my rear defroster.
Does anyone have a fix to this issue. No MODs have been done on the head unit at all. I'm ordering the Prestigious Society unit for the nav override, but I would like to get this issue fixed first.
Any suggestions????
Thanks GS Peeps.....
Any suggestions????
Does it happen only in a specific location or will it happen anywhere that you use the defroster?
Is it actually cutting out, or is it adding hum/hiss or other distortions.
It happens on all the FM stations.....
So, here is the update!
I called my service department at Cherry Hill Lexus in New Jersey, and they told me that since my is 2029miles out of warranty...there is nothing that they can do. I was given the Lexus Corporate number 1800-25-Lexus. So, I called and explained my situation to them. I was told that they would do everything that they could to fix my issue, and that I will get a call back within 2 days.
I mean...my car has 52029miles on it. I hope that they will be able to rectify my issue. Do you guys have any experience with Lexus Corporate?
As far as your issue, since the FM antenna is integrated into the rear windshield, I would venture to say that your issue is related to a short in the rear defrost wiring. Is there anything on your window that would be causing a short ... was the window scratched/defrost scratched, etc?
I believe that there is a signal booster for the FM antenna near the rear deck or C-pillar area ... maybe that has gone bad, and is picking up interference from the rear defroster.
Good Luck
Good Morning CL...
Any suggestions????
Any suggestions????
