How to remove speed limit?
Old 12-12-10, 04:19 AM
rickyb80
rickyb80's Avatar
Originally Posted by Dak6236
Guys,
i'm owning a japan spec GS350.
Quite fastuarted with the 180km/h speed limit.
Any advise to remove it?
many thanks
It's not like you need to go over 112 mph, but it's nice to be able to go over 130 mph once in a while when you're on an open stretch of asphalt with no cars around.......
Old 12-12-10, 04:32 AM
designo
designo's Avatar
My Middle East Spec GS460 is detuned by Lexus from 342hp to 322hp. But no speed limiters surprisingly. I saw the needle go past 260km/h and no sign of RPM cut off!
I wonder how fast a 342hp GS460 goes?
Old 12-12-10, 04:48 AM
Rider
Rider's Avatar
^ It has a speed limiter I guess..
Old 12-12-10, 12:25 PM
ghd8989
ghd8989's Avatar
Wow. That sucks about the drop in horsepower. It would be cool to get that unlocked through ECU.
Old 12-12-10, 03:13 PM
*Batman*
*Batman*'s Avatar
I don't know. The maximum I have been able to reach is 140mph limited by length of track rather than car. So I haven't been able to test whether the 150mph is a real limit or not. However the C&D test of the GS460 did say they were electronically limited at 150.
Old 12-13-10, 07:01 AM
Lexzam
Lexzam's Avatar
Given that the Euro-versions of the 6-speed gs300 go 149 mph, the 8-speed gs460 being limited to 155 mph, and given its power and gearing advantage over the gs300, my guess is that the gs460 should go - unlimited - around 160-165 mph (real speed, not the speedo reading which must be 5-10 mph more).
Old 12-13-10, 08:13 AM
*Batman*
*Batman*'s Avatar
I don't think this is right. Car and Driver found the GS350 to be limited by wind resistance to 136mph.
Old 12-13-10, 08:22 AM
GS350Lexus
GS350Lexus's Avatar
I hit 136 on my gs, then limiter kicked in and started to bounce of the speedo. It could of wen't easy 150 so wind resisitance isnt stoppin my 303 ponnies.
Old 12-13-10, 10:39 AM
designo
designo's Avatar
Stay tuned brother. I will be the first GS460 owner "online" to attempt this! I am very confident I can squeeze at least another 20 to 30hp out of my car.
I just received my ECU harness, awaiting the Apexi Neo to arrive anytime soon. I am going to get my lost HP back by leaning out my car back to 12 or 13.
Old 12-14-10, 03:39 AM
Lexzam
Lexzam's Avatar
Bizarre. C&D is lost in a big time. I've hit 130 mph with GS300 with great ease. Done the same with 2GS GS300 (the top speed in Europe for this car was listed as 143 mph), again easily...
Lexus could not possibly compete in this class if it did not hit the 149 mph and the 155 mph figures it claims alike its competition. 155 mph is jointly agreed and rather common governer limited speed for this type of cars in Europe. Let's not forget that there are no speed limits on many parts of the German Autobahns. 350 surely goes 155 mph unlimited. The drag co-efficient of 3GS is a low 0,27. The only possible limiting factor could be too short gearing, not the drag.
Old 12-14-10, 08:34 AM
designo
designo's Avatar
Middle East spec GS460
http://www.youtube.com/watch?v=NBX-s...eature=related
Old 12-14-10, 11:28 PM
rickyb80
rickyb80's Avatar
I wish I didn't have a governor on my GS450h. Here in AZ there are some really straight, flat, desolate roads that really afford the opportunity to speed. On my way home from work I hit 135 mph before the governor kicked on. It was pulling hard and very effortlessly the whole way with no signs of slowing down at all. Not to mention how stable the car felt too. If the governor was taken off the h I'm sure the car would max the 160 mph speedometer out with no problems.
Old 12-15-10, 02:02 AM
Lexzam
Lexzam's Avatar
...secrets revealed I guess.
Can you remember the revs at this speed? How about did you also check the speed from a GPS navigator, which should give a much more accurate reading.
Pulling well still at 265kmh (real speed probably at around 255 kph). It looks that the 460 should go over 265 kph (real speed).
It is said that while in Europe the manufacturers claim top speed 155 mph, in reality they let the car go a bit faster -- just because of this agreement on the common governor limit at 155 mph and avoiding marketing with the top speed.
btw..... all of those who experiment life beyond 130 mph....please make sure your tires have an appropriate speed classification for the job.
Old 12-15-10, 03:18 AM
dunnojack
dunnojack's Avatar
wtf, how did those arabs remove the speed limit?
our 350's are limited to 140.
we shouldn't have speed limiters. I wouldn't go that fast in this car anyway.
Old 08-27-14, 02:01 AM
warren52nz
warren52nz's Avatar
Default Speed Limiter
So I guess no one knows how to disable the speed limiter? All I'm hearing is don't do it.
Quick Reply: How to remove speed limit?
