Water leaking in my sunroof..
Hi everyone has water coming in from sunroof. Well today i drove my car into the drive thru car wash and see water pourin in even with it is close. I think my rubber around the sunroof is worn down i even can move it around with my hand on top of the glass.
So the question is HOW CAN I REPLACE THAT RUBBER AROUND THE GLASS ROOF HAS ANYONE CHANGE THIS BEFORE?
Thanks
Thanks
Take it to the dealership right away. You shouldnt be doing work like that on your car. If you get it wrong you are screwed. If the dealership doesnt fix it they are responsible for the repairs.
I recently had the roof liner removed from my car and the fram around the sunroof tightenede. It solved the rattle I had. I wonder if it would have leaked if it rained. I had issue at the car wash though.
Just take it tho the drive thru and look at the corner of the glass my was drippin the from the back right side you will see it or you can put your hand on top of the glass from the outside and try move it around to see if its loose.
mine is loose i have 90k miles on my 2006 gs i bet dealer will charge me an arm for it..
then why don't you buy the weatherstrip yourself, and try to fix it.
http://www.mylexparts.com/partlocato...layCatalogid=0
$50
$50
well the water is coming in thru the sunroof but it not soakin in the car dont want that to happen.. it was never loose at all just notice it yesterday a the car wash. thanks guy
