HID foglight Need HELP
I installed HID foglights on my car, but they won't come on now. Its pretty simple just plug the HID ballast to the original foglight bulb socket and plug in the bulb. Is there something special that I need to do beside that. Does the foglight run a different amount of watts or something. Please Help if you had ran into this problem. These are new HID btw
exclusive matchup
first of all try to plug in the original halogen bulb and see if it works, if not, you fried the fuse. like kevin said, stock is probably 20amp (if they have one fuse for both fogs), up that to 25amp should do it
if that's not the case, then probably you have the power terminals swapped.
exclusive matchup
cool, maybe cliff knows the trick too
on couple of my previous hid kits, i recall when looking inside the plug, there is a very little "hole" where the lead comes out. by sticky in a very small flathead, it will disengage the clip
but of course things can be different
