Front End Wobble
Front End Wobble
ANyone else out there experiencing front end wobble on extreme hard turns?
Mostly it happens when cutting the wheel to the extreme left through u-turns or backing out. It doesn't do it everytime but it happens often.
Anyone else have this?
mine makes a strange clicking noise in the front end...kinda sounds like a little wobblr if thats what you mean. but it doesnt happen during hard turns but when im backing out of my drive way and sometimes when i start moving....ive actually was wondering what that is anyone know whats up with that?
also is that kinda what your feeling and hearing?
Took it to the dealer today. The tech said the wobble was normal.
However, the tech did recommend new calipers and brake pads and brake fluid change. I ended up shelling out $500.
I had complained about the extremely low brake pedal a couple times and told nothing was wrong. This tech says different. Pisses me off I complained before and was brushed off. At least now the brakes feel almost as good as the GS350 now.
It does happen when backing uo with the steering wheel turned hard left.
If your turning the wheel all the way and doing U turns or backing out, its MORE THEN LIKELY the tire is hitting the plastics or maybe the fender... maybe rubbing against the inner part of the wheel well. The ribs/treads are making that vibrating feeling.
Sounds like you got roped. New calipers?... doubt it, maybe new pads and rotors.
