New owner with few Questions
Hi all
i am New owner and i have few Questions , i get my Lexus GS 350 10 days ago and i like it lot, there are some staff i like to ask to the ones who are export with the GS .
1-if i started the car and step out with the key in my pocket and go for 10 or 15 minuets what will happen
2- if i started the car and step out with the key in my pocket and some one treys to drive the car without the key is it possible ?
3- can i start the car and look it and come back to it ?
4-how can i make all lights light up when i open the car ?
thanks in advance
thanks in advance
I tried number 2 with valet the other night by accident. I walked away and they were able to park the car but they ran back and got me because once it turned off they needed the key to go move it.
Hi all
thanks in advance
thanks in advance
2. Yes.
3. No. You can only lock the car from inside when it is started. You could theoretically climb out of the window after locking the car...
4. On the roof there are three buttons for the interior lighting: DOOR/OFF/ON. Press the DOOR button. From outside, the car will light up as you approach with the key in your pocket, when you open the door the spot light will also come on closest to the door that is being opened (in addition to the interior lights).
Now I have a question for you - how did you get a GS 350 in Kuwait? They only sell the 300 here...
1. Nothing will happen except that the car will beep to warn you the key is not detected.
2. Yes.
2. Yes.
Anyways, to answer your question, in the navigation unit, I believe it's a setting.
You could also try searching:
https://www.clublexus.com/forums/sho...d.php?t=291517
