Check Engine Light - Check VSC
Old 01-30-13, 09:55 AM
  #166
TriniGS
TriniGS's Avatar
Originally Posted by ibidu1
Trini
What year is your car? looks to be 06 or 07, If that is the first time it has been towed thats very very good in terms of reliability.
If the fuel pumps are crazy expensive ebay has aftermarket pumps for less then $100.00
Yep its an 06, and correct first time been towed.
Old 07-20-13, 03:38 PM
  #167
APynckel
APynckel's Avatar
Just had this pop on today after filling up last night in my IS250.
Hoping it's just the gas cap, but I turn it to "click" once as the cap tells me to.
Old 07-22-13, 03:01 AM
  #168
yuup
yuup's Avatar
My 06 430 Check engine light came on a few weeks ago, I figured it was the gas cap but took it to the dealer anways to confirm. Cost about $90 to replace the gas cap. Grrrr It should be a TSB if all these cars are having the same problem.
Old 07-22-13, 03:54 AM
  #169
IXI187IXI
IXI187IXI's Avatar
you should click it 3 times. an easy way to tell if its the O ring is turn the cap till it clicks then start turning it as if your taking it off. if it only takes about 1/4 turn before you can take it off then you'll need to either get a new cap or just replace the O ring
wow $90? when it happened to me i just went to the dealer and bought the cap myself for $25
LexNYC83 (04-23-19)
Old 07-22-13, 09:04 AM
  #170
APynckel
APynckel's Avatar
Anyone happen to know the part number for a 2008 IS250 fuel fill cap?
Think I found it:
http://www.lexussouthatlantaparts.co...roduct=5783787
77310A 7730006040 CAP ASSEMBLY, FUEL TANK. CAP ASSY, FUEL TANK; (L)
7316 7731606070 GASKET, FUEL TANK CAP. GASKET, FUEL TANK CA
Edit*
Also, would a fuel cap from autozone or summit work? Or do I have to buy one from lexus?
*Update*
Must have been a loose gas cap. Re-tightened it, disconnected battery, reconnected, CEL gone. YAY!
Old 07-22-13, 10:12 AM
  #171
IXI187IXI
IXI187IXI's Avatar
Think I found it:
Edit*
*Update*
d'oh, clicked the wrong link, see post #173
Old 07-22-13, 10:38 AM
  #172
APynckel
APynckel's Avatar
Originally Posted by IXI187IXI
Being that that is an engine diagram, I'd bet that's the oil filler cap.
Old 07-22-13, 12:06 PM
  #173
IXI187IXI
IXI187IXI's Avatar
ha i just realized that when i checked the link. clicked on the wrong "cap" diagram. #16 here sorry about that
Old 07-22-13, 12:07 PM
  #174
APynckel
APynckel's Avatar
Thanks, went and had my car inspected and they found the cap to be performing properly. Just didn't give it time to pass the readiness checks (DOH!). So I have 15 days to get the readiness checks to pass and go back.
Old 07-23-13, 03:34 AM
  #175
IXI187IXI
IXI187IXI's Avatar
yea sometimes it takes a while to cycle. if the cap isnt clicked all the way, it will eventually throw those codes/errors.
Old 07-23-13, 08:05 AM
  #176
mrwilliams
mrwilliams's Avatar
I have the lights on and I was told it was a catalytic converter issue. I'm confused. If so how bad would it be to have one bad catalytic converter??
Old 07-23-13, 09:34 AM
  #177
C-SupraTT
C-SupraTT's Avatar
I picked mine up from Napa for under $ 15, worked like a charm, these caps are all the same.
Old 07-23-13, 11:44 AM
  #178
ibidu1
ibidu1's Avatar
If you have a 2006 GS300 and you have a check engine light you may have carbon buildup issues. The carbon will clog your catalytic, ruin o2 sensors, and make your engine run like garbage.
Old 07-26-13, 06:59 PM
  #179
mrwilliams
mrwilliams's Avatar
NNNNNOOOOOO!!!!!! I just got the engine rebuild a couple months back. Smh. I'm ready to sell and try to get a 2008 smh. This is my dream car and has been nothing but foolishness
Old 07-26-13, 11:00 PM
  #180
ibidu1
ibidu1's Avatar
If lexus did the carbon buildup rebuild, then you should be fine and whatever you have going on most likely it is something minor.
Quick Reply: Check Engine Light - Check VSC
