Listing of C-BEST (customizable features) avail on the 06 GS
Hi!!
Some of you may know that the 1K service (inspection) was recently (10/04) replaced by the Lexus Personalized Settings service. This new service lets you (somewhat) customize the keyless functions on your car.
I believe by "key out of ignition", they mean the car is off (Smartkey obviously is never in the ignition, unless the system is off or malfunctioning)
Here's a listing:
#. Name of the feature
How to use it/Description
O. Optional setting
S. Standard setting (Default on all 06 GS)
1. Unlock the driver's door/all passenger doors
By pressing the remote key door unlock button, the following functions can be performed:
O. Pressing the unlock button one time will unlock all doors
S. Pressing the unlock button one time unlocks the driver's door, and 2 times to unlock all
2. Flashing of signal lights
Using the remote key, the following functions can be performed:
O. Press the lock/unlock button on the remote key and the lights will NOT flash
S. Lock = 1 Flash, Unlock = 2 Flashes
3. Unlocking of doors when placing vehicle into Park
While the engine is running and the vehicle is placed into Park the vehicle can be programmed as follows:
S. All the doors remain locked when placing gear selector to Park position
O. All doors will unlock when gear selector is put into Park position
4. Auto locking of doors at 13 MPH
When the vehicle reaches 13 MPG, the vehicle can be programmed as follows:
S. The doors will not lock
O. All the doors lock automatically
5. Locking doors when shifting from Park into another range
While the brake pedal is being pressed and the vehicle is taken out of park and placed into another range, the vehicle can be programmed to operate as follows:
O. All of the doors will remain unlocked when shifting from Park into another range
S. All doors will lock automatically
6. Using remote key to open all windows
Pressing the unlock button on the remote key for 2.5 seconds, the vehicle can be programmed as follows:
O. The windows will not roll down
S. All the windows roll down
7. Using the remote key to open the moon roof
By pressing the unlock button on the remote key for 2.5 seconds, the following options can be programmed:
O. The moon roof will not open
S. The moon roof will open
8. Using remote key to open/tilt moonroof
When option #6 and #7 are active, the moonroof can be programmed as follows:
S. Moon
O. Tilt
9. Opening the trunk
By pressing on the trunk release button, located on the remote key, the trunk will open. The release button can be programmed as follows:
O. Press the button one time to release the trunk (no delay)
O. Press button 2x to release the trunk
S. Press and hold button for .8 seconds to release the trunk
O. The button can be turned off so the trunk cannot be opened using the remote key
10. Illumination of cabin light
After closing the door, the interior lights can be adjusted to stay on for the following:
O. 7.5 seconds
S. 15 seconds
O. 30 seconds
11. Illumination of interior cabin light when unlocking door
When pressing the unlock button on the remote key, the interior light can be programmed for the following:
O. Unlocking will not illuminate the interior
S. Unlocking will illuminate the interior
12. Delaying headlights to turn off
After turning the ignition and all doors are closed, if the headlights are ON or in AUTO, the lights can be programmed as follows:
O. Turn off immediately when driver's door is opened
S. Turn off in 30 seconds
O. Turn off in 60 seconds
O. Turn off in 90 seconds
13. Sensitivity of AUTO Headlight feature
While driving the vehicle and the headlight switch is placed in the AUTO mode, the front headlights can be programmed to turn on under darker or lighter ambient light conditions.
5 Levels, Level 3 is the Standard setting. 1 = Very light, 5 - Very dark
14. Auto tilt away of the steering wheel
When the vehicle is placed in park, the ignition turn off, and the key is removed from the ignition, the steering wheel can be set up to do the following:
S. Auto move up and away from the driver's position setting
O. Remain in the current position, as set by the driver
15. Auto recirculation of air when using A/C
When the A/C is ON or in AUTO, the vehicle can br programmed for the following:
S. To auto switch between the recirculation mode and fresh air mode as necessary to meet the temperature requirements set
O. When the climate control is turned on, the user must manually select the desired mod, recirculation or fresh air mode
Hope that helps anyone with questions regarding the little remote key fob features.
Here's a listing:
O. Optional setting
S. Moon
O. Tilt
O. 7.5 seconds
S. 15 seconds
O. 30 seconds
MultiTasking Mom
they have this for all 05 models and up. the list is included in the leather owners manual or online as xrave mentioned. apparently you have up to one year to have the complimentary service done. has anyone done it yet post-delivery? how long does it take and do you have to make an appointment?
better yet, has anyone figured out how to do some of these on your own (esp the door locking features). i did a bunch of the c-best settings on the RX myself.
MultiTasking Mom
Originally Posted by enigma354
Our LS, the 1st 'service' was a home checkup visit by a Lexus tech, who offered to do all the settings at home for us.
To my knowledge, CBEST settings are programmed using the Toyota Scantool... only some of the options can be changed via keyfob pressing combos, etc. (ie. 2004 SC 430 trunk popper button can be changed from instant/.8 second delay/off via the keyfob)
The options are pretty identical in all models of the same year (older IS didn't have that many features, newer ones do have more, but still not this many)
The flatrate time on the service is 1/2 hour. So it can take anywhere between 1 hour and 2 hours, depending on dealer load, appointment scheduled, and any other factors that may influence things as such.
But ya, as LexusLover stated, you have up to 12 months/unlimited miles to complete the service. It is NOT forfeited like the 1K was (1K can NOT be done after a 5K, 1K no longer exists for 2005 MY Vehicles sold after 10/04). Dealers, however, do get paid by Lexus if no adjustments are made. So choose wisely. I'm sure most dealers will adjust it again for you for free (assuming you're there for every service/repeat guest) but some may charge a fee (1/2 to 1 hour labor at their posted rate).
Batmobile
10-20-18 11:41 AM
sidwin
SC- 1st Gen (1992-2000)
12-20-12 11:14 PM
