Removing Nav screen of the 2006 GS(Pics)
Old 12-09-09, 06:00 PM
  #61
EyeKutr
EyeKutr's Avatar
Originally Posted by xxxalwayzspeedinxxx
i am trying to removel my navi and i only see two 10mm bolts , one for each side...? the instructions say 4 10mm nolts 2 on each side my car is a 07
https://www.clublexus.com/forums/1254048-post5.html
Old 12-10-09, 12:16 AM
  #62
alwayzspeedin
alwayzspeedin's Avatar
fond it didnt look high enough in the picture on that thread the lines pointed low i was looking everywhere ahahahaha, then i notice to cut outs in the plastic DUHHHHH
Old 01-10-10, 06:47 PM
  #63
roberam
roberam's Avatar
Thanks for the great pics, I need to take mine apart, spilled coffe and need to clean the buttoms.
Old 01-10-10, 09:04 PM
  #64
BinaryJay
BinaryJay's Avatar
When I took mine apart I found a whole set of keys and some of what appeared to be pieces of doughnuts under there along with a bunch of loose change.
Old 01-10-10, 10:30 PM
  #65
rominl
exclusive matchup
rominl's Avatar
no kidding, the cup holders when you open / close, it can act like a black hole...
one time i was installing something for someone, found a key, and she was so happy saying "omg i have lost this mailbox key for months!"
Old 05-16-10, 07:22 PM
  #66
GS350Lexus
GS350Lexus's Avatar
Originally Posted by VVT-i
You will need a small flat head screw driver, a phillip head screw driver, a 10mm socket and a towel to protect the navigation unit.
First, remove the plastic trim underneath the nav( just right above the ashtray) by pry it out with a small flat head screw driver.
Hint: Tape the screw driver with Scotch tape to protect the finish of the trim.
Hey,
Thanks a lot for the detailed DIY dash removal, its very easy to follow. Expect maybe u can add that the 2 10mm bolts are hidden behind a black plastic thing because i couldn't find them for about 10 minutes.
Old 09-13-10, 07:11 PM
  #67
dj4ever101
dj4ever101's Avatar
thanks so much needed to know how to remove my radio
Old 09-14-10, 12:26 PM
  #68
Vin1971
Vin1971's Avatar
Originally Posted by rominl
wow this is some good pics man, so anyone wanna take theirs apart as well?
imma try tonite on mine..wish me luck!
Old 05-02-11, 07:26 PM
  #69
windsuf
windsuf's Avatar
Default Viastech
Thanks a ton for the pics, just ordered my kit from prestigous systems,
anyone here using viastech and if so which model.
Old 05-03-11, 02:16 PM
  #70
rominl
exclusive matchup
rominl's Avatar
i have sl2i-up. really depends on what you want out of your system
Old 09-04-11, 12:34 PM
  #71
NaLexus
NaLexus's Avatar
Please, help me. I did the DVD hacks like others, but mind is not working and navi screen say like "contact the dealer and no internal memory". On the other hand, i can play DVD in motion but not the Navi. Do you think, because i unplugged all the connctor from the unit. Thanks in advance.
Old 02-20-12, 09:45 AM
  #72
uptownboi
uptownboi's Avatar
wow... thanks for the clear step-by-step procedure write up!!!
Lukas99GS
09-07-16 02:11 AM
inrisls400
03-09-16 07:11 PM
dreyfus
ES - 5th Gen (2007-2012)
29
06-27-12 12:37 PM
tctitan
IS - 1st Gen (2001-2005)
03-23-07 12:55 PM
sursmoke
01-05-06 08:12 PM
Quick Reply: Removing Nav screen of the 2006 GS(Pics)
