Please Help.... Check engine light
I'm getting P0440, P0441 and P0446 after installing HPS cold air intake and cat back exhaust. I disconnected negative terminal when installing everything, AFTER searching the forum I read that these codes can pop up if the EGR hose isn't connected, so I triple checked my connections and still am getting a light about every 7 days after I clear the code. Any thoughts....
Do you have a 2GS3 or 2GS4? On my '99 GS400 these hoses were causing my P0441/P0446 codes. They were brittle and cracking. You may have to lift the engine cover to get to them.
Turned out to be a simple fix for me (vapor line disconnected) - top of engine towards driver side.
It’s the exact lines pictured above. All three codes are history (P0440, P0441 and P0446).
firelizard (01-11-20)
mbrown1782
02-26-13 07:53 PM
