2nd Gs300 studs
2nd Gs300 studs
I have factory studs on the front of my 2000 GS 300 & I was doing a test fit to mount 20's under it. The problem I came across is when I tightened the rims up, it's like the nuts are deep inside the rim. Should I go with longer studs or is that normal? Please Help
First, welcome to the club and forum.
Second, You have OEM nut and the rims that you try to use on your car, the hallow are different and bigger. That is way your OEM nut go true on the rims. Go to any Wheels shop and the guys there tell you the best nuts set for those rims that you try to use on your car.
Thanks!! 👍🏾
Sheehan1p
08-17-14 10:40 PM
