Best 10" replacement subwoofer?!?
OP obviously im a little jaded since i went for a massive sub
BUT as i said the Pioneer Shallow mount will work with very little effort, its a free air but it adds more bass than factory and leaves the trunk space
i used a 12" sub and had to trim just a slight bit before i went completely overboad for the sub i showed above
I installed this new Rockford Fosgate using factory bolt holes. I added lots of foam padding around the subwoofer to avoid rattling. It sounds very good inside, more then enough bass. Thank goodness I got a good dental plan bcuz it really knocks hard.
My door speakers have 6 1/2 Kicker speakers powered on a separate 4 channel amp.
BTW - if you ever need custom door speaker adapters, I recommend this place, is where I got mine:
http://car-speaker-adapters.com
For those of you that have replaced the OEM 10 with aftermarket 10,
are you using the factory levinson amp still?
What sub are you using?
How long have you had it?
How do you like it?
Thank you!
How do you like it?
Thank you!
spxChrome
05-19-11 09:33 AM
