Code p1349
Code p1349
I have a V8 GS400 with code p1349, I am getting mixed responses from 2jz owners associated with this code, they say to change the OCV filter? Is this correct ?
The filter is a screen that could be cleaned unless it's broken. Most likely problem is the OCV itself. Common issue.
Also you say you have a 400. Why would you be talking to 2jz owners about a problem with your 1uz? A good measure is to replace both OCV's due to age
It was a general question , ando the 2jz Owners were the only ones responding when I asked, it was on Facebook, so that's my fault and probably the problem, that's why I joined this forum, thanx for the response. I cleaned both just in case, so far no code, but I will replace both of them soon like u said, as a good measure . 😊
