Upper Control Arm Replacement Cycle?
Old 02-09-16, 10:50 AM
Alphaman19
Alphaman19's Avatar
Default Upper Control Arm Replacement Cycle?
Had my aftermarket upper control arms on for about 4yrs/120k miles on NJ roads.
Any idea on how long they last and/or when I should replace them?
thanks
Old 02-09-16, 01:09 PM
sakataj
sakataj's Avatar
When they go bad, replace them.....next thread please
Old 02-09-16, 02:56 PM
Alphaman19
Alphaman19's Avatar
yea, maybe that's my underlying question; How do you know when they're going bad?
Old 02-09-16, 09:46 PM
firelizard
Forum Moderator
firelizard's Avatar
In the words of Jason Derulo...
wiggle wiggle wiggle
Same as checking any balljoint, you're checking for play. You can do this by (with the car's front safely and securely off the ground) firmly grasping the front wheel at the top and bottom and attempting to rock it . If there is play in either the top or bottom balljoint, you may feel it. You can also inspect more closely by taking the wheel off. If you see the rubber boot is split and grease is leaking out, plan on replacing it sooner rather than later. If the boot is split and the grease is already gone, that balljoint has been dry for some time and its life span is extremely short if not already ended. It would probably have been making noise even before it got to that point. Clunking from play, horrible creaking if it's dry.
Old 02-10-16, 02:05 AM
isfdude
isfdude's Avatar
They will make a popping or clunking noise when they go bad. You can also check them by jacking the car up and moving the wheel right and left and in and out from the bottom and top of the wheel to see if there is any movement. If there is something is loose/ worn and needs replacement.
Old 02-10-16, 08:26 PM
firelizard
Forum Moderator
firelizard's Avatar
That's good advice.
DshngDaryl
04-27-22 02:00 AM
kontrazeus
09-29-17 08:33 PM
gsCrazy
Suspension and Brakes
06-22-09 06:13 AM
TexusLexas
05-05-09 04:32 PM
SCpwner
30
08-28-08 10:15 AM
Quick Reply: Upper Control Arm Replacement Cycle?
