Car doesn't respond to keys anymore?
Old 08-19-15, 04:34 PM
Foob
Foob's Avatar
Default Car doesn't respond to keys anymore?
I've got a problem with my 1998 gs300, neither of my master keys currently work with my car, both keys have brand new battery's, and were working previously on the car. But a couple months ago I installed a whole new sound system into my car including a new headunit. (Kenwood ddx372bt) ive tried reporgamming the keys using the whole lock unlock 5 times put key into ignition and all, but the car doesnt regonize the keys, it goes into programming mode but doesnt react when i hold down the buttons on the keys. Car still starts up fine, trunk opens fine. But on occasion the engine misfires in one of the chambers, causing me to turn the car off and turn it back on again. Or sometimes the car doesn't even recognize the keys and doesn't fire up, just keeps trying to start up. Looking inside the car the key to ignition light doesn't flash when the doors are all locked. But if I open the passage side front door the alarm goes off, until I put the key into the ignition and put it into the on position. Took it to a toyota dealership yesterday cause I have a connection there he tried to program the keys and it didnt work. He told me that it could be either a fuse that has burned out or has a bad connection. Called lexus a few weeks back and they said I would need new keys and a New ecu, sounds extremely expensive. Any help is greatly appreicated!
Thanks
Old 08-20-15, 06:21 PM
Mr Jokster
Mr Jokster's Avatar
If its happening with multiple keys, its quite obvious its not a key problem, but (as Lexus said) an ecu problem. So they're correct. If it were a blown fuse, it wouldn't work at all, not work intermittently so thats a big . loose connection in the cylinder is a possibility, doesnt hurt to open up the dash and see if anything is loose back there.
I highly doubt the stereo install had anything to do with it, I think it just coincidence. Cant blame the last thing done to a car for a problem... cars get old and break
You could save a pretty penny if you can find a wrecked GS at a wreck yard and get the ECU and keys from.
Old 08-22-15, 06:02 AM
Mcon
Mcon's Avatar
What up Foob,
Call this 2 guy in South Fl. Both have a few GS300 and GS400 for parts. (954) 588-4147 Hollywood and this one is in Ft. L (954) 423-1100
Old 08-22-15, 11:43 PM
Category5
Category5's Avatar
Yup DEF. Sounds like an ECU issue. I have a ECU and 1 key if interested.
Old 08-23-15, 07:31 PM
speedkar9
speedkar9's Avatar
When the problem happens, does the security light go out or does it stay flashing?
You might want to try to program another immobilizer key.
If opening the passenger door with the driver's door closed always makes the alarm go off, you have passive mode enabled in the alarm settings, which activates the alarm 30 seconds after you closed the driver's door. Annoying I know...
Skip to 3:10 to get to the menu in techstream:
Old 08-23-15, 10:08 PM
Foob
Foob's Avatar
*Mr. Jokster: By wouldn't work at all you mean the car wouldn't start? Or that the car wouldn't even react to the keys period, because that's exactly what's happening now. Haven't gotten a chance to open the dash up cause classes are starting haven't gotten a chance to.
Thanks Mcon, if I happen to need to get a new Ecu I'll give them a call.
Thanks Catagory 5, will let you know if I need a new Ecu and key.
Speedkar9
Ill have to check tomorrow morning about the flashing light. Will update sometime tomorrow. I tried programing both of my keys neither were even recognized as keys from the car, it would just remain in programming mode.
Old 08-24-15, 08:54 PM
Foob
Foob's Avatar
Well I'vd got no flashing on the key indicator in the car. When car is off and I'm out of the vehicle for longer than 30 seconds. Even checked the morning after no flashing.
bayview777
05-02-15 08:00 AM
kim812251
RX - 1st Gen (1999-2003)
11-27-12 11:40 AM
GSE25
03-22-06 10:09 AM
aristogirl
CL of Southern California
03-02-06 12:27 AM
W4SIM
SC- 1st Gen (1992-2000)
07-06-04 03:20 PM
Quick Reply: Car doesn't respond to keys anymore?
