no power from stop in D. Alternator?
I am just wondering if this is the alternator going bad, SOMETIMES when I shift the car into D the car will not move until I give it gas, it just feels like it has less power. I think I notice it most when i havent taken the car for any highway rides to charge the battery and have been doing mostly short trips. I know my alternator was weak last time I checked, just wanted to make sure that this is something a weak alternator can do? Or can this be something else?
Report back with your findings.
Here a useful link i used as well - http://densoautoparts.com/sites/defa...ing%20tips.pdf
Check your throttle cable for proper tension, also when was the last time you cleaned the throttle body? Doing those 2 things fixed my cars charging issues. Also get a multi-meter and test the voltage at idle and at 2000 rpm warmed up. Also check out the battery, should have 12.6 volts after driving it.
but if it worked for you...
Not your alternator, doesnt even really make any sense if you think about it. If your alternator dies you will run on battery and wont see a difference besides your battery/vsc lights.
I would do a simple tune up and go from there. Clean maf and throttle body, also replace air filter.good luck
I bought one of these http://m.ebay.com/itm/290946457765 to help me read some codes. I had to get the wifi version because it works with my iPhone 4. With different phones you can get the Bluetooth version that is cheaper. I bought the app OBD Fusion. Not only can I read codes but among many of the useful features I can see voltage.
thats what I was thinking as well. I will look out for a battery light. In my experience the light only comes on when the alternator is really about to crap out as that happened in my Acura a few times before it died completely. When it is a andom power loss that I feel only happens when I dont drive my car on the highway enough and have taken only short trips, it seems like a battery charging issue,but autozone replaced the gel battery with a new one and they said if it still happens it is most likely the alternator because it is "reading a little low". I remember him saying something like it should be reading at 12 and mine is reading at 11. SOMETHING like that....
I will see if this happens again because now that my car is being driven on the highway I am feeling like the car is a litle faster. My heart is telling me alternator.
At the end of the day, the numbers don't lie, you're either getting a good readout from the alternator or you're not. Also if your alternator dies, the car will use the reserve capacity on the battery until that is depleted and then you'll have no power at all.
Well my car was idling lower than oem spec therefore my alternator wasnt giving me the required voltage to charge my car at idle, i adjusted the tension on the cable and it immediately started idling higher and i was then getting a good reading from the alternator, car works mint now. The throttle allows air into the car, so if it was super dirty, this would prevent air from getting into the engine efficiently, therefore idling improperly.
OP it is not your alternator. The only possible way it could even related is if your battery was bad and your alternator is going out. Even then your dash light would go crazy with the battery light vsc abs lights in the dash.
choithew
Performance & Maintenance
16
04-08-14 09:59 PM
