thermostat help
thermostat help
Hi there, I have a 00 gs300 black on black. A few weeks ago i noticed my radiator was seeping fluid so i replaced it with a denso unit And topped off my coolant (red) but now the car will only heat up if I'm idling, i can drive 80mph for 30 minutes and the car doesn't heat up to operating temp. I believe the thermostat might be the cause. This leads me to the question of where is the thermostat located? Off the water pump or up top where the upper radiator hose goes into motor?
Thanks Josh
Thanks Josh
Well i grabbed it and moved it hard enough to shake the car but it didn't budge. just to confirm that is the correct location for the thermostat right?
Thank you i had taken a pic of that area to post and ask but you've confirmed It. Are there any abnormal steps to draining refilling and replacing thermostat?
2000 gs300 thermostat location
Here's a pic incase someone else has this question.
Also a pic of the ride
Got the new thermostat in today problem solved the old one had a broken internal gasket.
persian451
01-02-07 07:23 PM
