P0300, p1351 & p1354
My '01 w/ 170+K showed the following idiot lights today.
CEL / Oil / VSC / VSC Off
I pulled the codes and got P0300. P1351 & P1354
Going to do the OCV filters on both side even though my codes are only for Bank 2
BTW V-8 GUYS yes gs400 and gs430 use the same part #'s
part # for drivers side 153400F010 $88.89 (with sewell discount)
part # for passenger side 153300F010 $88.89 (with sewell discount)
https://www.clublexus.com/forums/per...-filter-5.html starting at post #67 (Thanks sakataj)
Oil & Filter Change
Spark Plug Change
Shoulfd I be looking at anything else ?
Oil & Filter Change
Spark Plug Change
I have exactly these codes today, did you ever find a solution?
Have been having trouble with the bank 2 OCV codes, even after I replaced with new ...now that P0300 is supposed to be on bank 1 - but now codes for the VVT there.
Long story short, was getting "P1354" after I had front oil seal replaced, replaced the proper OCV with proper Toyota part, but code came back...even paid someone to go back in and adjust timing a notch - they couldn't figure out the P1354 (Japanese Engine Specialists). Just haven't done it again yet because hate to buy 2 OCV valves and it not be the problem.
Thanks!
Thanks!
Oh, ok - interesting to know! In my case it is P0301 (cylinder specific to #1 then, yet opposite bank of the valve in question)...sorry for not making the distinction!
Burteboy was kind enough to respond with this info on a related thread as well (thank you man, I DO appreciate it):
"Guys only use dealer oil filter, i have seen oil control valves code came on because the filter for the ocv was clogged by the oil filter/filter. It came apart . oil change is a must at regular interval."
Yikes - oh my
Yikes - oh my
kevintown
12-14-13 11:42 AM
