98 GS400 Replaced Transmission Mount
Old 02-09-14, 07:00 PM
DNAARISTO
DNAARISTO's Avatar
Default 98 GS400 Replaced Transmission Mount
Just putting my $0.02 in on this. Today I replaced my transmission mount. I went to Oreillys Auto Parts and purchased mine. It's was $104 out the door with a lifetime warranty. The brand name is Anchor and part #9644.
It was easy,4 size 14 bolts on each end of the crossmember, 4 size 12 nuts in the center of the crossmember that is attached to the bottom of the mount and 4 size 12 bolts that hold the mount to the bottom of the transmission.
The aftermarket mount looks way more solid than the oem mount and had added bulk to it.
I replaces mine because when.I accelerate I could feel the motor shift towards the back of the car, plus I had vibration in the center of the car.
I just attached pics to show how bad mine was and how the new one looks.
Old 02-09-14, 08:03 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
How many miles on your car and amy specific torque specs? di you install on a lift or on jack stands in garage..
Old 02-09-14, 09:19 PM
DNAARISTO
DNAARISTO's Avatar
130k ish miles, I used a jack and 2 jack stands. You will have to use the jack to lift the transmission back up order to line up the crossmember again. And I did look up Any torque specs, probably should have.
Old 02-10-14, 09:16 AM
islexusred
islexusred's Avatar
have replaced the 2 engine mounts as well? mine need to be replaced like BAD
Old 02-11-14, 01:57 AM
SC4Paulo
SC4Paulo's Avatar
Replaced mine in the sc, very straight forward, motor mounts were too gone for me to feel a difference
Old 02-11-14, 09:29 AM
repugnante
repugnante's Avatar
Easy job. 15-20 minutes tops. Did it in my boy's driveway.
....and I agree, they are much more solid than the OEM's. Kinda makes me wonder if Toyota opted to cheap out on this part. OP, which brand did you get? I ended up getting DEA's because this was an emergency repair and they were all I could get my hands on in a short amount of time
Old 02-13-14, 04:25 PM
DNAARISTO
DNAARISTO's Avatar
Not yet that is the next step.
Old 02-13-14, 04:27 PM
DNAARISTO
DNAARISTO's Avatar
I went with Anchor. I've had DEA mounts on another car, and I have had a bad experience with them. I know that Anchor is a better brand, plus got a life time warranty. So I can't complain.
WIL44
07-06-21 03:00 PM
RGW LLC
04-15-15 03:18 AM
ScWift92
Build Threads
28
07-13-14 08:41 AM
bigblack06
07-27-13 04:28 PM
BigWaveSC
Suspension and Brakes
16
07-21-10 07:04 AM
Quick Reply: 98 GS400 Replaced Transmission Mount
