Clearance issues behind double din
Old 01-25-13, 11:38 AM
doug118
doug118's Avatar
Default Clearance issues behind double din
I'm not sure how many people on here have an aftermarket double din with 3 sets of RCA cables installed but for the ones that do, how do you get everything to fit? I'm having the hardest time squeezing everything in behind the radio and I only have 1 set of RCAs plugged in and still have 2 more to install.
If there are any tricks out there to making the install easier, please tell me!
Old 01-25-13, 04:38 PM
TTurboPimp
TTurboPimp's Avatar
Its been a long itme since I installed mine, but I do remember it is real tight back there with three sets of RCA's and all of the other plugs......it will fit though. Refresh my memory, does the stock plastic air vent tube run behind the radio? If so, you can heat it up with a heat gun until its pliable enough to "form" aorund the radio when you push the radio in to give yourself that little extra clearance. I didnt have to do that though. If you put the radio in without the ash tray in there, you can alos reach up there a little to help work the wires out of the way.
Old 01-25-13, 08:50 PM
doug118
doug118's Avatar
Yes the air box is right behind it. There is some sort of support piece that the bottom of the radio bolts to that makes things much much harder to install. I may cut the center of it out to give myself some room and go from there. Heating that plastic up and pushing it in does seem like a very good idea also. Thanks
Old 01-26-13, 04:41 AM
Chin
Former Sponsor
Chin's Avatar
What I basically did is place the radio into position about half way, then slowly/carefully pull all your wiring/connections down with your free hand so that they end up under the radio and moreso behind where the ashtray will mount. There is more room down there. Also at first, I had my harness and connections neatly cable tied into one large harness, this looks good but its very bulky, i had to break down that one large harness into 4 smaller harnesses and spread them out in order for the radio to sit flush.
Old 01-26-13, 07:12 AM
TTurboPimp
TTurboPimp's Avatar
I did exactly what Chin did.....I didnt have to cut or heat anything up on my set up.Just take your time and you will get it in there
Old 01-26-13, 02:58 PM
doug118
doug118's Avatar
I'm starting to think my dash kit is a piece of junk also. I wanted one with a beveled edge and the only one I found was $10
Old 01-26-13, 03:30 PM
1sWt2GS
1sWt2GS's Avatar
get the oem one, it matches perfectly
Old 01-26-13, 04:38 PM
TTurboPimp
TTurboPimp's Avatar
agreed, I went with the OEM one as well
Old 01-26-13, 10:50 PM
whit3b0y
whit3b0y's Avatar
its not easy just take your time and it will fit. Try to stuff all the stuff on the sides.
Old 01-27-13, 05:16 AM
doug118
doug118's Avatar
Best place to buy the oem one?
Old 01-27-13, 08:42 AM
NorthStyle
NorthStyle's Avatar
Carson
http://l-tunedparts.com/product/?id=1726
Old 01-27-13, 10:52 AM
Mr Jokster
Mr Jokster's Avatar
Zip ties are your friend. Zip each little cluster together and you can easily 'stuff' the wires to the outer sides. If you have external bluetooth, theres room right above the a/c outlets.
as said above, just take your time, there are plenty of places to cram the wires, zip ties makes it more manageable.
Old 01-28-13, 02:24 PM
doug118
doug118's Avatar
Originally Posted by NorthStyle
Does this come with plastic of metal brackets?
Old 01-28-13, 04:26 PM
Mr Jokster
Mr Jokster's Avatar
___________
Old 01-28-13, 04:30 PM
doug118
doug118's Avatar
Lol thanks for taking the time to do that instead of just saying yes. I wasn't sure if for any reason there were plastic brackets from the factory
Quick Reply: Clearance issues behind double din
