How to do the rear view camera without edge from keyhole?
Old 01-22-13, 05:10 PM
Acer
Acer's Avatar
Default How to do the rear view camera without edge from keyhole?
I installed an old rear camera today in my keyhole but it has a ring from the trunk bar.Takes half the screen?Is there a way to get it more flushed or what camera has a better fitment?
I got this camera for $20 a while ago.
Old 01-22-13, 05:22 PM
Mr Jokster
Mr Jokster's Avatar
Pictures will help with a cure. Without seeing it, first thing I can think of is trim the trunk bar to size.
Old 01-22-13, 05:30 PM
Acer
Acer's Avatar
I did trim it a bit , I will get pics asap.
Old 01-22-13, 09:41 PM
clos430
clos430's Avatar
What kind of camera did you use ?
Old 01-22-13, 10:49 PM
AVSRacing
AVSRacing's Avatar
just wondering does anyone know of any specific cameras that solves this problem or fits nicely in the key hole. as this is where I plan to put my camera in too.
Old 01-23-13, 02:09 AM
1sWt2GS
1sWt2GS's Avatar
Haven't got around to doing this but want to. Pretty self explanatory?
Post up a DIY!
Old 01-23-13, 05:36 AM
Acer
Acer's Avatar
I have one of these cameras without the mirror.
It was really easy just remove the trunk bar,keyhole lock.
I attached the camera with zip ties lol.But you can't tell, its covered by the trunk cover.It doesn't' shake and it's firmly in place.
I used a heat gun to heat the back of the trunk bar key hole enough to get it soft then I used a screwdriver and rounded it.But it's still not enough.I think I need a bullet type camera?
Attached Thumbnails How to do the rear view camera without edge from keyhole?-12716850400.jpg   How to do the rear view camera without edge from keyhole?-jyuiu.jpg   How to do the rear view camera without edge from keyhole?-uiuhikgy.jpg
Old 01-23-13, 05:37 AM
Acer
Acer's Avatar
Sorry ****ty phone quality,
Old 01-23-13, 07:02 AM
sakataj
sakataj's Avatar
lol, it needs to come out of the trunk bar (sorry old bad pics)
Old 01-23-13, 09:14 AM
repugnante
repugnante's Avatar
Is this compatible with the stock nav unit?
Old 01-23-13, 09:29 AM
clos430
clos430's Avatar
I have the same set up Brian had ( sakataj ). When I was doing some SEARCHING his thread popped up and I used the same camera he used since I liked how flush it sits. The only problem is that you can't see the rear bumper, but I'm still modifying it to make it stick out at an angle.
Old 01-23-13, 10:30 AM
Acer
Acer's Avatar
lol o ok I'll see if I can get it more flushed with the trunk bar.Did you use any type of gasket/sealant? Around the lens.
Old 01-23-13, 11:48 AM
sakataj
sakataj's Avatar
......................sorta. i used a system to integrate it into the nav from here
https://www.clublexus.com/forums/gs-...-its-done.html
yeah i wish it pointed down more so you can actually see the ground but it is what it is i guess
gasket, my camera came with it
Old 01-23-13, 01:02 PM
repugnante
repugnante's Avatar
Yea I did a little search on this and saw your post Brian. Looked like you had your hooked up to the stock nav unit (when you still had it) I'm gonna look into this a bit further. Thanks!
Thanks for not railing me either B. I know I could've searched on that question I asked. Good look!
Old 01-23-13, 01:34 PM
Acer
Acer's Avatar
Sakataj what camera do you have?
Quick Reply: How to do the rear view camera without edge from keyhole?
