I'm looking to wrap my wood grain in carbon fiber. I was wondering if I shud remove the wood on the door and then wrap it, or shud I wrap it With the wood attached to the door??
remove the door panels, they screw in from the back. The center console pops right out. The door panels are easy to remove as well. I can have all door panels off within 15 mins, having done it a million times.
There are some 10mm screws on the bottom and on the side; there's about four of them. Once those are off you can just pull the panel out, and you have to unplug the harness. It'll still be stuck, just lift the door panel up.
