PCV valve replacement would you be worried?
Old 06-23-12, 01:00 AM
lexo98
lexo98's Avatar
Default PCV valve replacement would you be worried?
While I was replacing the PCV valve and grommet I lost a small piece of the grommet in the valve cover. The old grommet was dried up. Would you be worried?
Old 06-23-12, 07:20 AM
LuxuryGS3
LuxuryGS3's Avatar
Deifnitely. You don't want anything falling in there.
Old 06-23-12, 08:10 AM
99 GS3
99 GS3's Avatar
It's pretty common to happen, it may be fine, but it may not. If you haven't ran the car yet just take the valve cover off and find it. Not too bad of a job to do.
Old 06-23-12, 09:57 AM
JeffTsai
JeffTsai's Avatar
Best to take off the valve cover and shake the little piece that came out, but realistically it's not a huge deal. There are 3 pretty deep baffle up there inside the valve cover that prevents anything from falling in. I think you'll be ok.
Old 06-23-12, 12:35 PM
lexo98
lexo98's Avatar
Is it funny that I'm kinda star struck right now? Jeff you cars are the ****!! Thanks for the input. I was able to stick my pinky in there and the piece pretty much disintegrated. I'm not feeling to bad about starting it up now. Thanks for the input fellas!
Old 06-30-12, 01:43 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
OP... Is the PCV easy to replace.. Do u just take off the engine cover and its there? I recently bought the small valve, grommet, and PCV cover as sort of a preventative maintenance thing. thanks
Old 06-30-12, 02:05 AM
chicov8
chicov8's Avatar
its easy to replace pcv valve except grommet which is hard to remove in one piece
Old 06-30-12, 01:02 PM
GS4_Fiend
GS4_Fiend's Avatar
I only changed the pcv. My gromet was still fine
Old 06-30-12, 01:44 PM
krispl
krispl's Avatar
If you haven't started the engine yet then try using vacum to suck it out. Is it on I6 or V8?
Honestly little piece like this shouldn't hurt anything. I wouldn't go through all this trouble taking cover off especially if it's a V8.
Old 06-30-12, 05:15 PM
tmf2004
tmf2004's Avatar
I thought in order to get to it that its under the engine cover.. I have a GS400..
Old 06-30-12, 07:25 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
PCV valve is a piece of cake. Pop out.....pop in
it's smart to change them frequently.
Old 06-30-12, 10:36 PM
lexo98
lexo98's Avatar
I have been driving for a week now and everything seems ok. BTW its a v6. Krispl that vacuum idea was a damn good idea. I think I'm good though
Old 07-04-12, 08:19 AM
tmf2004
tmf2004's Avatar
So does the engine cover need to come in a GS400 to get access to the valve. thanks
Old 07-04-12, 10:36 AM
GSteg
GSteg's Avatar
Engine cover needs to be taken off, but not the valve cover. It's an easy install.
Old 07-04-12, 03:15 PM
tmf2004
tmf2004's Avatar
thanks henry...
Quick Reply: PCV valve replacement would you be worried?
